Elgin 1907 Pocket Watch
Hello, I just cleaned and oil my first pocket watch, good news
is now runs !
It has a small lever on rim that locks watch so it cannot be time
set after movement is in case. From pocketwatchdatabase ad
for watch says: "Patent self-locking setting device."
 Why make watch so it cannot be set to the time by crown
after movement in case ?? You do have to remove movement
from case, change lever and then you can change time if lever
was in " lock ". When lever in " unlock " the crown setting always
works.
Good morning and congrats on your success. Do you have photos of the watch and movement and the lever in question? The Lever you seem to be describing is typically for when the watch is outside the case so you can install the hands.
Hello, I wil add a photo to this reply. The lever is on front rim of movement I think about 3 oclock under dial plate. My
watch together working so I don't want to remove dial to get better picture. It took be hours to get hands on and
not hitting each other. I used my phone to take a picture every 5 seconds while I worked on watch, the picture I am
adding to this reply is one on them. Looking at picture about 1/2 inch to left of my thumb there is a silver lever on
rim held by one screw. The lever is connected to keyless yoke by linkage. When lever end (at edge of movement)
is down (level end can be moved about .25 inch on rim) the crown works for setting time. When lever is up the time
cannot be change using crown. Once movement is in case, the lever is held in place by case. Again, watch in case with lever
up time cannot be changed using crown. The advertisement for watch says " self-locking setting device ".
The lever pivots on single screw holding it in place.
13 hours ago, FLwatchguy73 said:
So yes, as I remember it that lever is for placing the hands on the watch, and this has been discussed here before. Others here will know exactly what it is called, it just escapes me. At the moment, naturally.
This lever does no lock the hands, it only stops the crown from
moving them.
Does the movement actually need to be removed from the case in order to change the position on the lever or do you just need to unscrew the bezel holding the glass on the front of the case? Perhaps it would be useful to post a pcture of teh watch in its case with the case open.
The rim lever is under the dial. The case has screw on front, body
with stem and crown, and screw on back. To change lever you must
remove movement from body. The movement. only will come out
the front and the movement. two screws that hold movement to
body are on rear of movement. Therefore, the front and back must be
removed, then take movement out of body. The inside body rim holds
lever in " locked " or " unlocked " position. A picture with case front
removed only shows the watch dial, the lever is under dial.
I guest this it the mystery, why would you make a watch that can be
put in case and the time cannot be set without removing movement
completely from case ?
I think you may be able to remove front, remove back, turn 2
movement holding screws 1/2 turn, tilt movement up just enough
to move rim lever then but back together.
I would take more pictures, but I had such a time with watch hands
I am not going to remove dial again.
Edited by lakeradio6
add more
Go to YouTube, search video by " staying sane "
see his video Elgin 293 Disassembly
at 4.01 into video you can see levet at 6 o'clock at very bottom of
screen, it is in up, locked poistion. see linkage to keyless works.
Movement put in case this way time cannot be change by crown.
I seem to remember reading somewhere that one of the requirements for some railway time keepers was that the hands could only be set by removing the bezel to access a lever in the rim of the movement so that they couldn't be inadvertently altered. I don't recall any need to remove the dial though.
Is it possible that this is a movement that has been recased and redialed using parts that don't accommodate this feature?
I originally suspected that this was a re-cased railroad movement but having seen the patent I don't think it is. It is a stem setting not a lever setting but for some reason unknown that lever is there. now I am as intrigued as the OP.
The movement you are referring to is called " levet set ".
Lever set watch had a pull out levet at about 1 o'clock.
To set time remove just front of case, with finger nail pull out
lever then with crown set time. After settling time push lever
back in and then replace front, now crown will only wind watch.
Search YouTube lever set watch and see many videos.
A very good video of my mystery level at 3 oclock is on
YouTube: staying sane video " 1917 Elgin 16s grade 293 assembly.
at between 15 and 16 minutes into video Mr Sane clearly
moves rim lever to what I call down position . This allows setting
time using crown. I have asked Mr Sane what lever is for.
Not sure in he will answer or knows answer, but I would bet
he knew to move lever down.
The movement in his video is same as mine.
Please see my reply to Marc below
My watch and rim lever is very clear on YouTube video
  • 3 years later...
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
