Elgin 1907 Pocket Watch
Hello, I just cleaned and oil my first pocket watch, good news
is now runs !
It has a small lever on rim that locks watch so it cannot be time
set after movement is in case. From pocketwatchdatabase ad
for watch says: "Patent self-locking setting device."
 Why make watch so it cannot be set to the time by crown
after movement in case ?? You do have to remove movement
from case, change lever and then you can change time if lever
was in " lock ". When lever in " unlock " the crown setting always
works.
Good morning and congrats on your success. Do you have photos of the watch and movement and the lever in question? The Lever you seem to be describing is typically for when the watch is outside the case so you can install the hands.
Hello, I wil add a photo to this reply. The lever is on front rim of movement I think about 3 oclock under dial plate. My
watch together working so I don't want to remove dial to get better picture. It took be hours to get hands on and
not hitting each other. I used my phone to take a picture every 5 seconds while I worked on watch, the picture I am
adding to this reply is one on them. Looking at picture about 1/2 inch to left of my thumb there is a silver lever on
rim held by one screw. The lever is connected to keyless yoke by linkage. When lever end (at edge of movement)
is down (level end can be moved about .25 inch on rim) the crown works for setting time. When lever is up the time
cannot be change using crown. Once movement is in case, the lever is held in place by case. Again, watch in case with lever
up time cannot be changed using crown. The advertisement for watch says " self-locking setting device ".
The lever pivots on single screw holding it in place.
13 hours ago, FLwatchguy73 said:
So yes, as I remember it that lever is for placing the hands on the watch, and this has been discussed here before. Others here will know exactly what it is called, it just escapes me. At the moment, naturally.
This lever does no lock the hands, it only stops the crown from
moving them.
Does the movement actually need to be removed from the case in order to change the position on the lever or do you just need to unscrew the bezel holding the glass on the front of the case? Perhaps it would be useful to post a pcture of teh watch in its case with the case open.
The rim lever is under the dial. The case has screw on front, body
with stem and crown, and screw on back. To change lever you must
remove movement from body. The movement. only will come out
the front and the movement. two screws that hold movement to
body are on rear of movement. Therefore, the front and back must be
removed, then take movement out of body. The inside body rim holds
lever in " locked " or " unlocked " position. A picture with case front
removed only shows the watch dial, the lever is under dial.
I guest this it the mystery, why would you make a watch that can be
put in case and the time cannot be set without removing movement
completely from case ?
I think you may be able to remove front, remove back, turn 2
movement holding screws 1/2 turn, tilt movement up just enough
to move rim lever then but back together.
I would take more pictures, but I had such a time with watch hands
I am not going to remove dial again.
Edited by lakeradio6
add more
Go to YouTube, search video by " staying sane "
see his video Elgin 293 Disassembly
at 4.01 into video you can see levet at 6 o'clock at very bottom of
screen, it is in up, locked poistion. see linkage to keyless works.
Movement put in case this way time cannot be change by crown.
I seem to remember reading somewhere that one of the requirements for some railway time keepers was that the hands could only be set by removing the bezel to access a lever in the rim of the movement so that they couldn't be inadvertently altered. I don't recall any need to remove the dial though.
Is it possible that this is a movement that has been recased and redialed using parts that don't accommodate this feature?
I originally suspected that this was a re-cased railroad movement but having seen the patent I don't think it is. It is a stem setting not a lever setting but for some reason unknown that lever is there. now I am as intrigued as the OP.
The movement you are referring to is called " levet set ".
Lever set watch had a pull out levet at about 1 o'clock.
To set time remove just front of case, with finger nail pull out
lever then with crown set time. After settling time push lever
back in and then replace front, now crown will only wind watch.
Search YouTube lever set watch and see many videos.
A very good video of my mystery level at 3 oclock is on
YouTube: staying sane video " 1917 Elgin 16s grade 293 assembly.
at between 15 and 16 minutes into video Mr Sane clearly
moves rim lever to what I call down position . This allows setting
time using crown. I have asked Mr Sane what lever is for.
Not sure in he will answer or knows answer, but I would bet
he knew to move lever down.
The movement in his video is same as mine.
Please see my reply to Marc below
My watch and rim lever is very clear on YouTube video
  • 3 years later...
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
