Watch dial
Hi all. I recently purchased a Leonidas Bidynator automatic watch to restore. I have repaired and serviced the movement and polished the case but I am not sure what to do with the dial.
It was in very poor condition but a light clean in water revealed small amounts of what looks like silver but the rest has worn off leaving just base brass.
my question is, is this silver the same as a clock dial and could be resilvered using resilvering powder or would I be better off painting it.
I have attached a picture of what I believe to be the same watch in good condition.
as usual many thanks in advance.
Edited by Specializedjim
Added photo
The dial is in a bad way. You can't re-silver that dial, looks like the numbers are fixed, you could have it restored but that will be expensive. Your best bet is to look for a replacement dial. You could look on the various suppliers sites or try ebay.  I also note the hour wheel is missing.
Thanks for your help. Yes your right it is bad and from what I can see it’s also quite rare.  Can you answers the following for me please.
You said the numbers are fixed and I already noted they are not pinned through the dial. So are they glued?
If I could get the numerals off and polish the dial to a good state could I resilver (do you think that’s what it was originally) or would paint be better.
well spotted on the hour wheel I already have a spare.
many thanks for your help.
You say it is quite rare. I would have it restored by professionals. I'm not sure how the numbers are fixed. I have only re-silvered Long Case Clock dials which is fairly easy with the right materials.
Hi again
I have had ago at restoring the dial using spray paint and a ink jet printed numerals etc. I think I will have another go at it now that I have a better idea of what I’m doing but I think it looks ok for a first attempt. Also the completely knackered movement I repaired seems to be going well so overall I’m happy with my efforts for a £20 punt. Let me know what you think. Many thanks for all the help received.
Now, redo it, but take lots of photos/video and repost as a how-to. I feel like dial refinishing is one of those semi-lost arts. They were cheap/unloved, and so were either parted or tossed, and anything with any value was done professionally. Dial refinishing needs to stage a serious comeback in the DIYverse.
Hi again
WOW !!! great job ...
I've been "playing with dials" for some years now and I'm amazed how quickly you did that ... congrats !!!
Now your oldie looks like a 4925 ...
Envoyé de mon moto g(7) power en utilisant Tapatalk
Very true! And this is the reason why I am here on the board to find ways to fix my dial of Omega 155.006, but haven't found a solution yet
  • 1 year later...
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
