AS 1802 vs 1803 Hour Wheel
Hi all - I'm working on an AS (A Schild) 1803 movement. The hour wheel has a couple worn teeth that are slipping on the minute wheel. Seeking a replacement, I saw Jules Borel interchange said the hour wheel is interchangeable with that of the 1802. Everywhere I find hour wheel on the internet, they are labelled as AS 1802/03. However, they are different. In short, the 1803 is thicker so that it can catch the intermediate date change wheel. The wheel on the 1802 (non-date version) is thinner, and slides below the date change intermediate wheel (not engaging).
Am I missing something? Trying to confirm these parts are, indeed, not interchangeable. In any event, if anyone has an 1803 hour wheel, I cannot find one! See pictures, and thanks in advance.
3 minutes ago, rogart63 said:
1950 has that kind like the left . Sure it isn't from a 1950 . The 1950 is a no date. Therefore lower then the 1802. Or even a 1800/01
Thanks for the reply. Yeah, the no dates are likely all the same. Given the part (#255) is often referenced as interchangeable, I was trying to validate that they are indeed NOT interchangeable or whether there is some trick/method to swap one for the other...
Yes it's just a matter of looking if it is a date or no date version,I also took a look since this is based on the ST (Standard) movement which other had the same one, seems to be a bunch to choose from.
CaseCaliber Factory Number:AS 1902 255 Hour wheel
AS 1060
AS 1710
AS 1712
AS 1800
AS 1801
AS 1802
AS 1803
AS 1900
AS 1902
AS 1940
AS 1941
AS 1950
AS 1951
AS 2062
AS 2072
AS 2160
AS 2162
ELG 314
ELG 960
ELG 973
ELG 996
GIR 132
GP 142
STA 1800
STA 1802
ZOD 65
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
