First Watch Build, Feedback Appreciated
Tom32
Hi all,
This is my first watch build. I started it in January 2020 with no previous experience of watches or watchmakers tools and it's been quite a learning curve but hugely enjoyable.
It runs on a Miyota 8215 movement that appears to be working well (after a few issues with hands getting stuck).
Total Cost of materials was £115.
I've never owned an automatic watch before so am enjoying wearing this, but I think the dial looks pretty bland without some form of personalisation.
I'd appreciate any thoughts on how it looks now or how others think it could be improved. I've had a great time on this project and am happy with the cost, but would be interested to hear what others think of the total cost of the build, does it seem worth it?
Cheers,
Tom
  • Like 7
A nice job very tidy. As far as "was it worth it", In my estimation YES you started knowing very little and now have a better understanding of watch anatomy. In terms of self satisfaction and accomplishment well worth it and you should rightly be proud of your achievement so a resounding   WELL DONE:Bravo:       You want your name printing on the dial where the normal logo goes as this is a first.
Thank you very much.
That would be ideal, do you have any recommendations on printing options? I've seen a few tutorials on water transfer prints that looked good.
3 minutes ago, JerseyMo said:
it is not so much the cost but more of the reward to know 'you did it'.  of course now you will want to built another and another
Exactly that, I thought I had finished it a few times in the last two months but it turned out had missed something and needed to order a new part. So to get it finished today and have it actually work was fantastic.
I have the parts for a watch suitable for use in my job on the way which I'm looking forward to putting together. Assuming that goes well, it would be a challenge to try stripping and rebuilding a movement.
The interesting bit is trying to print white on a black dial.
Most modern print methods rely on using dark pigments on a white background (white paper).
There are some options which would allow white, gold, silver etc to be printed on a clear waterslide background, but you would need to do some experiments to see how to do this in practice.
I would suggest you look at laser toner printing and heat transfer films which bond a pigment on to the toner using heat.
There are a couple of dial printing threads on this forum that you might like to explore.
I think the word 'interesting' here means challenging! I'll have to track down those threads and see what I need to give it a try, and find out what the heat could do to the dial as it is now.
Thanks Andy.
That is not how the process works.
It is more akin to this.
1) Print dial designs on to clear decal slide toner paper with a laser printer, in black toner.
2) Pass said designs, still on the sheet, along with a piece of the metalised or white/coloured heat transfer film through a pouch laminating machine.  This fuses the transfer foil material to the decal paper and you should end up with a decal that has white, gold, bronze or whatever, in the places where your black toner is.
3) You use the water slide decal in the normal way.
You can use the laser printer to do the heating, if you don't have a pouch laminator, using tape, but this is risky as you may end up with glue from the tape on your laser printer fuser rollers.
Here is one of many guides from the interwebz that shows the process done that way.
https://cedarcanyontextiles.com/outrageous-idea-transfer-foil-to-paper-with-a-laser-printer/
Note, your design is limited by the resolution of the laser printer, and these are typically around 600dpi. Inkjet printers will produce finer detail, but they cannot be used with heat transfer foils, and generally can't print white, unless you go for some very specialised and expensive printers and inks.
Ah I see, thank you for the link.
I'll need to decide on the design (and then find the software to create it), but I think this option definitely has legs.
I've ordered a few spare dials so I'll have these to practice on. I'll be sure to post the results.
4 hours ago, Watchtime said:
really nice project you have completed here. And that without any experience..wow:thumbsu:
Thanks very much, I did have a lot of help from this forum and spent plenty of time trawling the internet for guidance. It's been a hugely satisfying endeavour.
19 minutes ago, AndyHull said:
Also worth a read is this thread.
Thank you. This is exactly the thread I was looking for. I read it in January but lost the bookmark.
I appreciate the software recommendations as well, looks like a productive weekend ahead!
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
