Making staking anvils
jdm
I have restored the below which is nice but  a bit quite limited. So I thought of turning few anvils or extra stakes  to complete the set - mainly for show.
What are the essential shapes / sizes that are recommended, and what material? I can also list the included stakes
You'll want to get some 4.7mm rod for stakes, for stumps I use 8mm. I don't know what metals are available near you, in the U.S. the standard would be O-1, here the standard for watch parts (and it works fine for tools) is Sandvik 20AP. Sandvik products have become difficult to get and the price has skyrocketed; there is a terrific metal supplier Klein Metals who make equivalents to Sandvik products. Their LAW 100pb is a direct replacement for 20AP, and LAW 100x is a direct replacement for Sandvik's non-leaded replacement for 20AP. All of the above are easily heat treated and very forgivable regarding exact hardening temp (i.e. heat to orange, quench, clean up, and temper to color needed).
http://www.kleinmetals.ch
As for shapes, most useful is a range of fairly simple stumps with varying hole sizes in them. For punches, the most used are convex tip with hole and flat face with hole, in incremental sizes for doing riveting work (staffs), convex with no hole (closing holes), flat tip of varying diameters for knocking out pins etc., and then concave tips which get used less often but can be handy. Any other special shapes are best made up as needed. For one-offs I frequently use brass for stumps, no need in many cases to use steel and do heat treatment.
Here's a pic of some of my stumps (and pushers for the jeweling tool), looks like a mess but I know where everything is! The ones in the plexi holder get the most use.
  in the US we have "drill rod"  oil or water quench.   i don't know the metal formula,  but it works good for me.   vin
That would be O-1 in most cases (oil quench), or W-1 (water quench). Available in any diameter imaginable, at least O-1 is, and flat bars. I wish it was available here as it's dirt cheap, available everywhere (there), and an excellent tool steel.
Hi NIcklesilver  quite an array of tool stumps, impressive.     It can't be a mess if they are your tools and know where everything is.  It is organised.  stay safe
What keeps it fun is although I'm "independent" I share a workshop with a 4 man company, a numbers guy, a technical guy (designs/engineers the stuff) and two watchmakers. All great guys. The watchmakers are young and poorly tooled, so I give them free reign on my tools, machines, everything. So it does happen that I go for that favorite stump or broach or micrometer or whatever and have to make the rounds to find it. Usually makes for a much needed break!
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
