Can anyone help with info on this movement please?
eezy
This clock was liberated from the Belsen WW2 prison camp by my father. He was one of the first into Belsen and this clock was in the Commandant's quarters. There is a note somewhere, currently mislaid, from within the clock which contains Commandant Kramer's name. It sat on the mantelpiece at my Father's and worked everyday up until about 2006. I think it is an 8day movement.
The movement is signed Kohler and the case  has Berchtesgaden and Bergen on it. I cannot find any info at all onthe 'net.
I dont know what information you are looking for but your clock is by Christian Kohler GmbH they manufactured clock cases from 1913, they did not produce their own movements, and bought and cased these from other makers and signed them under their own name the movement in your clock is by a company called Friedrich Mauthe there may or may not be a Mauthe trademark stamped on the clock this would be a eagle with the letter F M S in a circle your clock would be pre war and date to the 1930's.
The movement is an 8 day bim bam sometimes called a ting tang  with rack striking. It has an anchor escapement. I can’t add any more info about the manufactured movement, wls1971 has said it all.
I have been to Berchtesgaden in the Bavarian Alps. That is where Hitler had his Eagles Nest retreat. I have also been inside many of the underground bunkers, fascinating place.
Gents, thank you both for the information, exactly what I wanted.
With the name Mauthe, I have been able to find a wealth of information. Not so with Kohler though, there seems to be very little about. Hence I have not been able to find a link to Berchtesgaden and can only assume that Kohler had a base there.
Thanks again
  • 11 months later...
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
