Hello All..
ash145
Hi all, new today. Have been admiring Marks videos over the past few weeks...top bloke!.. :thumbsu:
I spend way too much time tinkering with watches.Collect mainly older 60's70's style. Omegas, Bucherer Chronometers (my favourites!), Rado's, Mido's. Dread to think how I'd cope with 80's technology!!.
I really admire the eta and ASchild movements of that era.
Anyway, look forward to getting to know you all.
Ash.
