Stereo Microscope
I love quality but IMHO cost must be reasonable for the intended (hobbyst) use. So I'm putting the $32 link anyway :biggrin:
https://www.aliexpress.com/item/32634442471.html
This is x20 magnification. I can get up to x270 mag with an optional eye piece. X70 in current configuration which is great for looking at wheel teeth, jewels and hairsprings. Plus progressive linear zoom from x20 to x70. I love the well made piece of equipment.
  • 4 months later...
On 1/22/2015 at 5:42 AM, Marc said:
I don't usually use my microscope in general disassembly or reassembly; for that I use a clip on magnifier attached to my glasses that has a lens for each eye so I retain stereo vision.
The microscope comes into its own for inspection, oiling, and hairspring work, where the higher magnification really makes a difference. It's also great for detailed cleaning and restoration on dials partly because of the magnification but also peering down a microscope cuts out all of the peripheral distractions so your total focus is on the job in hand.
I do use a conventional loupe as well but that tends to be for inspection only as I find working without the ability to properly judge distance is less than ideal. Also, I work at desk height rather than bench height (something that I have to sort out as it's not so good for my back) which means that I am above the work, where the screw drivers need to be, so higher magnification loupes (with correspondingly closer working distances) are less than practical. As and when I eventually get a bench sorted out loupes may become a more viable proposition. What I have in mind is to have the working surface more or less at shoulder height when I am sitting upright. This would place the work in front of my eyes not below so there would be no competition for space with tools.
I'm glad that I continued reading this thread. I almost bought a stereo microscope for general disassembly And reassembly work. So then can you give me more information on your clip on magnifiers? I now use a loupe but would rater have stereo and a bigger field of view. Thanks for saving me some big bucks..
@martygene at the time I made that post I was using a 3x clip on magnifier by Eschenbach same as this . Not the cheapest available at about £45 to £55 but very good. They have become a little scuffed since then but do still get used occasionally.
The biggest issue I have with them is that my spectacle lenses partially counter the magnification.
I have since acquired a vintage Binomag head set.
These can be picked up off eBay for between £15 - £25, the lenses are glass so don't scratch too easily, and are very comfortable to use. These are also about 3X mag but because I can use them without my specs I get the full benefit.
Working distance for both the Binomags and the Eschenbachs is about 100mm (4") and width of field about 8cm (a little less with the Eschenbachs).
I now also work at a bench the top of which is at upper chest height when I'm seated so posture issues are a thing of the past too.
My microscopes sit on a desk next to the bench so they are also at a much more useable height.
  • 2 months later...
Im interested too especially any good info about microscopes. Id like to be able to see the work and archive the work on my computer. Any good and cost efficient equipment out there? I also wasnt able to open the link
There are some topics in this subject already, better take a look at those.
The price most often reflects the quality but all depends what you will do with it.
You might find some nice ones in the link below..
I've seen these and have wondered if they'd make for a decent Youtube tool. The descriptions I've seen leave some uncertainty as to how exactly they work. Does anyone know whether the magnification is merely variable by altering the focus (changing the working distance and magnification as a consequence)?
Regards,
Regards,
That was my concern too. On the short research ive done, it seems most of the cheaper scopes sacrifice that working space for magnification. Yes it will magnify but its better suited for a science class maybe
If I didn't have a microscope already, this is what I would get.
https://a.aliexpress.com/_Bf9BlrRT
Get a 10X eyepiece, a 0.7X - 4.5X zoom objective lens. If you want to increase the working length, get a 0.33X or 0.5X auxillary lens. You'll sacrifice some magnification for for the increase in working length. But it'll be more than enough for watch repair work.
    • @Murks the problem you have mate is most watch cases out there to buy are for Seiko NH3X, ETA 2824 and maybe Myota 8XXX movements, oh also the big ETA 6978/9 movements which the dials start around 28.5mm. You might find one on a Google search but I suspect your main chance will be buying cheap quartz ladies watches and hopefully find one of the right size and condition that is acceptable. 😞   Tom
    • The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be. You've signed up to another forum !!! Why you defector , you snake in the grass, you infidel consider yourself shunned.... you.......you........you CAD  😅😅😅😅😅😅🤪
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
