Stereo Microscope
I'm considering getting a stereo microscope, around the £400-£500 mark. Someones recommended this one to me
Ebay item  191085725004
which I've almost brought a couple of times this week, but can anyone give me an alternative recommendation.Also having never actually used one (which is probably the reason I've hesitated on buying it) do they make life easier, are they easy to get to grips with?
Lee
Hi Lee,
That looks like a nice piece of kit, albeit somewhat over specified.
I have been using a Wild Heergrugg M5 now for about 4 years courtesy of an amazing car boot sale find and I wouldn't be without it. For me the advantages are a much better view of proceedings (obviously) and a much more comfortable working position as it allows a more upright seating stance, not so hunched up. Proper stereo is important for judging distance.
My setup gives me 6, 12, 25, & 50 times mag as standard but it came with an attachment which allows control over depth of focus and increases mag by a factor of 1.25. I use 6 & 12 for most stuff, 25 for hair spring work, and 50 for inspecting jewels and pivots. More than that is of little or no use. One very important factor is working distance (how much room between the watch and the object lens when in focus) as you have to be able to get your tools in there. Mine varies from 12-15cm if I remember rightly which is fine. The one you're looking at states 10cm but that may well change with different magnification, and if that is the max then it's worth asking exactly how it changes as this may well restrict its usefulness. One other word of warning; cleanliness takes on a whole new meaning under 50x mag. Be prepared to get a bit obsessive about it (not a bad thing in a watchmaker).
It's quite a lot of money to shell out though so worth asking about the working distance. And if restricting the mag to 50 - 75x saves money then that's worth considering as you won't miss the higher mag in practice.
Have fun.
to be honest I haven't the faintest idea what I need. the one I linked was one another watch repairer has & he sent me the link. the specs are boggling I assume I need a zoom version for ease? & I like taking images of things I do to (currently use a USB microscope & a camera.)
Lee
http://www.ebay.co.uk/itm/Trino-Zoom-Microscope-with-Single-Arm-Stand-for-electronics-inspection-solder-/191085725004?pt=UK_BOI_Medical_Lab_Equipment_Lab_Equipment_ET&hash=item2c7d98c54c
Lee
Im looking for a stereo microscope myself. The only problem this microscope needs to be ordered from germany. I understand an adaptor is available to increase the working distance to 100mm from actual lens to subject. Rememeber also cheap zooms equals poor quality...better with fixed focal length. A microscope would definitely make life easier. There are others options which you can order from within the uk. Let me know your decision.
I got my Inspection style microscope from Brunel Microscopes ~ £180
http://www.brunelmicroscopes.co.uk/longarm.html it's excellent and having a longer focal length gives plenty of room for tools. I also bought a USB eyepiece camera to take watch movement photograph's
That looks a good option Odyseus. What like is the image viewing quality with the lens supplied...is their diopter adjustment.
Edited by djmcd
I did look at that one Odyseus which is why I asked the question "I assume I need the zoom version" because I liked the price of the Brunel one, but thought the eBay one seemed to have more spec.
I just got the standard version but I also bought lower power eyepieces too (x10 is standard and I also bought some X5 eyepieces). The microscope comes with three objectives and I use the lowest power one.
It really is an excellent microscope for working on watches !!
Unfortunately it's my experience that it just isn't possible to have all that you need in this game. There will always be another gadget, widget, or tool that you just can't do without. Or is that just me?
Sent from my GT-I9305 using Tapatalk
These stereo arm microscopes are a lot easier to use and work with than loupes IMHO :)
Yes the BM1 doesn't have variable zoom. ( you have to change the objectives ) but mine is always set for minimum zoom and that's perfect for working on watch mechanisms. !!
If you look on my blog, you see some photo's taken with USB microscope eyepiece CAM !!
I hope you're getting commission for selling these? I too have been thinking about one for quite a while now.
This watch business fair gets a grip o' ye!
What is the distance between the centre of the vertical column and the centre axis of the objective lens when the extension arm is straight?
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
