Hi all
rgus
I have been a pocket watch collector for a number of years and decided to learn how to  clean and maintain them.   I am looking for an L & R Varamatic watch cleaner with the ultrasonic head.  Anyone have one they want to sell?
Have you ever taken apart, inspected cleaned in a jar, lubricated, reassembled and tested a (pocket) watch before? Because the gained ability to do that in is much more important than semi-automatizing the cleaning process, something that becomes important only to workshop doing many pieces per day. And you have some many more important tools to worry about before that piece of machinery.
FYI we have a dedicated section here where it's considered polite for new members to introduce themselves.
