Fixing my Late Brothers Watch
This watch was working up until recently when the stem came out. I can still insert the stem & wind but cannot set it.
I've tried all local watchmakers without any help. The Factory advised it was a 60's branded watch made here in the States.
I would love to get it repaired...fond memories require it.
Any help greatly appreciated.
G.B.
My condolences GB. To keep busy with watchrepair, the watch is very likely to be undamaged, just the set lever and set spring are disengaged or broken set spring at worst. I am using an old Ipad right now which can,t access the pix you posted. All needed is a close up of the keyless, you would need to remove the hands and dial plate to uncover the keyless. Best wishes Joe
Its a valuable watch that obviously has great sentimental value for you as well so I would not recommend doing anything yourself to the watch a picture of the stem would help a great deal of these watches where one piece cases and the stems where what would be termed a split stem.
Any competent watchmaker should be able to work on these watches.
That case looks to be what is called a monocoque case, aka one-piece. As Nucejoe says, it's probably simple. However, for a newbie the case will present a difficulty. The crystal has to be removed by using with the right sized clamping tool or blown out through the pendant/pipe, where the stem goes in.
It looks like a very nice quality, and quite striking looking, dress watch. Any jeweler/watchmaker that does anything other than replace batteries and sell earrings should know that it's a once-piece case that takes special treatment, but is not daunting. Sorry about your losing your brother.
Mark Lovick, the guy who runs this forum, has videos on youtube under thewatchrepairchannel. He shows how to improvise to blow the crystal out. That said, once it's out, you do need a special tool to get it back in. Good luck.
My WAG is that both pieces came out and then they came apart. I certainly could be wrong. Regardless, the movement will have to be removed in order to make it right again. You don't want to lose those stem halves, as they are rather hard to find.
Despite the job being pretty straightforward for someone who has worked on watches a bit, it's not a good job to attempt yourself. Especially on a watch with sentimental value. If you have to remove the dial to get to the set-lever that engages with the stem, there's a good chance of damaging that very nice dial and/or hands. And when you damage the dial yourself  you never forget it. Every time you look at the watch and see the scratch(es), you'll be reminded. Don't ask me how I know.
Here is all I know of the origins of the watch...I contacted what is left of JJ..
Thank you for the photos of your watch. I fully understand and appreciate its sentimental value and it appears to be in good condition. Unfortunately it’s US produced and we have no spare parts for it. However, I believe the watch is fitted with a standard Swiss movement and a local US watchmaker should be able to replace the broken stem.
Best regards,
 HANS RYSER
 Senior Advisor & Brand Ambassador
Just not sure yet how I should proceed.
GB
Was the watch running before the stem pulled out? If so, it's likely that there are no parts needed. If there are parts needed, and it's a generic movement as JJ says, you should be able to get parts. If it needs a mainspring I'm sure the right size and type could be found. I don't know why you're getting a bit of a run around with it.
You just need to find a capable watchmaker (Doesn't have to be an old master.) who wants to help you. It doesn't look like a tall order to me.
11 hours ago, GomBoo said:
Western NYS...
GB
Just find someone local who seems like a real watchmaker and not a battery-replacement person. The NAWCC may have a list of reputable repairers in the USA. Otherwise, there are other Americans here who I’m sure will offer advice.
It appears that the old saying, "If you want something done right, do it yourself", has become "If you want something done, period, do it yourself".
In a state like NY, you shouldn't have to work so hard trying to give somebody a bit of money for watch service.  Strange times.
Probably assembled  here.with a standard  or perhaps  more elaborate swiss movement.  Worth your time.as it is a nice watch with sentimental  value. I would  suggest that while having it repaired  you have it cleaned  and lubricated  as well. The stem is held in place by a lever which may be broken.my first guess would  be corrosion. The watch is stuck in the wind position. When an attempt to set it was made the lever snapped. But this is only a guess..any competent watch repairer  can do it. Unfortunately  I can reccomend  no one. If you do an image search on keyless works you should  be able to see how it works.it isn't at all complicated
Edited by yankeedog
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
