Seiko 7S26 glass measurement
Hello!
I have to find a glass for a Seiko but I don't have the old model, it has been delivered to me with no glass.
How do I should mesure the diameter and height?
I have the old gasket on place, should I mesure with the gasket on or without it?
Thanks for your precious answer.
Edited by Nednico
12 minutes ago, Nednico said:
Oh thanks, very useful! Sorry to abuse but If I want to order from, for example, cousinsuk.com, with is the best around here, how can I find the exact size and shape the I need?
Not sure who has one to be honest. You can call GS directly and they may be able to help you. I contacted them about my Sicura Satellite. They did't have that info on file, but they may with a Seiko branded watch, especially if you have the manufacturers part number. Their customer service was excellent. They won't sell to you, but they can get you a part number and you can go from there. Their phone number is at the top right on the first page.
https://gssupplies.com/crystal-catalogs/?gclid=CjwKCAjw-YT1BRAFEiwAd2WRtqEhwu6RTe6_xsg8ltSEsNJS-eP5As8CQr_HONnDtW3aufNej2cMJBoCnxMQAvD_BwE
It's a flat mineral crystal, 1.5mm thick. Size is measured with vernier calipers with gasket in. Link given above tells Ø 30.5mm.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
