Valjoux 7730 vs valjoux 7733
Does anyone know whether the dial feet changed between these 2 movements? I found a Breitling dial for sale, that looks exactly like what I need except it is being advertised as a 7733 while my watch is a 7730. Thanks
7730 was basically a Venus 188
7733 was completely redesigned but same fonctions as 7730
I think the position of subdials are the same but I'm not 100% certain ...
Envoyé de mon moto g(7) power en utilisant Tapatalk
One can see dials as these at Ebay marked fitting 7730 or 7733 but as you say seldom together.
Probably not to get a too many franken watches beeing built. I have non of these needing service right now so I decided to make an experiment.
Take a random picture from one who sells a dial to a 7730 dial and one who sells a 7733 and superimpose them over eatch other.
A fun excersize on a sunday. The result except from a slight skewness in the pictures shows the dial feet are at the same place.
Edited by HSL
I can use any info! Thanks
The original Venus 188 and the early 7730 had a flat pillar plate.
The later 7730 and the 7733 had a beveled pillar plate.
What you could do is to remove the dial from your 7730 and check if :
- your 7730 has a beveled pillar plate
- the holes for dial feet are about 12:45 and 8:15
If YES then a 7733 dial may work.
If your 7630 is an early one and has a flat pillar plate, then probably not.
  • 9 months later...
I appreciate that the original post is a little old now, however thought I'd share some info to assist this and others that may have similar questions.  So I have a couple of Cal 7733s and a recent purchase of a 7730. As called out in previous responses, there are two variants of the 7730, with either a flat or beveled pillar plate - mine is the beveled, the later version.
Being the newer beveled version, I was expecting a 7733 dial to fit nicely, however it does not.  Whilst the dial feet are in the same positions and the sub dial pillars line up nicely, the bottom dial foot (midway between 7 and 8 clock) is marginally closer to the centre of the movement that on the 7733.
So in summary a 7733 dial does not fit my 7730 movement.
I hope it helps..
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
