Seiko 7006 5000 Can't Remove Stem
I have a Seiko 7006 5000 that has the odd case—TV dial shaped. I know there is a lever located in the notch at the 2:00 position but I've tried for two days to get the stem out with no luck. Is the dial on this watch screwed on? I was about to remove the hands and lift the dial off, but I suspect it is screwed on. The only alternative left is to cut the stem and replace it. I would really like to keep the stem intact if possible. Any suggestions would be greatly appreciated.
Regards...
Are you pressing on the lever from the dial side? If so that’s your problem. There is a hole that you can stick a needle or pointed object into from the back of the movement. The dial is held on by screws which can be located around the edges of the movement you will know them when you see them because you will see the dial feet right next to them. If you can’t get stem out then you will have to dismantle the keyless works and the hands and dial must come off in order to do that. And that will 100% need to be done if the keys are locked, can you still click the the stem in and out? And if you do get the stem loose make sure the stem is clicked in before you pull it out and do so gently so the keys don’t lock on you
Edited by saswatch88
Thanks, but this is the Seiko that comes out with the case back attached. The face of the case lifts off leaving the movement incased in the case back. There is a tiny hole in the dial side at the 2:00 position that allows you to take a tiny pick or screw driver to depress the lever. This is a very odd Seiko and many have not had experience with these watches.
Edited by DavidMasters
The only way I see is to try to carefully rise the movement over the edge and see if it's possible to access and turn the eccentrics. Be carefull not to take off the dial feet, it's easier to find a new stem/crown than soldering the feet again.
Hi David I have attached the tech sheet for the seiko 7006  there is a note on it regarding stem removal. Hope you find it of some use.
Thanks to both of you. You two know of the actual watch I am having problems with. It appears the lever is extended when the crown is pulled out, but under heavy loupe I do not see the lever—probably a problem left by the previous hands in the movement.
I will no doubt make more work for myself if I break the dial feet, so on to the cutting tool and the removal of the stem. I will show a picture once off...
Regards.
Not the outcome I was looking for. While trying to pry the dial I broke a foot, but I was able to get to the lever. The red arrow points to the lever that should be pressed down through the notch at the 2:00 position on the dial. That lever then pushes UP on the lever pointed to by the blue arrow. However, the red arrow lever was/is frozen which made it impossible to remove the stem. After I got the dial off I was able to pry UP on the blue arrow lever and remove the stem.
If someone in the future needs to remove a stem I suggest bending a small screw driver blade. Pull the stem all the way out which extends the blue arrow lever. Insert the screw driver toward the stem day/date window and attempt to pry up on the blue arrow lever. None of these parts are visible via loupe through the notch.
I hope you have better luck than I did.
Regards.
1 hour ago, Watchtime said:
Finally....:thumbsu: dialfeet are plenty on Ebay, in the worst case use a dialdot
Dial Dots are in the way back part of my desk, so I'm ready. I hate using dots, but they work. Since all the watches I work on are mine and will never leave I don't mind once in a while. I've also used 3M double-sided tape trimmed to the proper size.
Thanks.
Thanks.
Hi David, I'm also working on a Seiko 7006. But mine is a conventional backloader, not a frontloader like yours.
My watch also has a broken dial foot. I did consider using a dial dot. But there is hardly anywhere to place the dot. How do you intend to place a dial dot?
The case on my 7006-5000 has the benefit of a press fitted crystal/gasket. After I placed the movement back in the Back case, I laid on the rubber gasket and sat the crystal in place. Placing the Front case on the movement/Back case and pressing into place there is a tight press fit, so, the dial will not move even without feet. I happen to have some 3M double sided tape here and I cut a tiny strip—maybe less than 1 MM—just to hold the crystal until it was in the case. That was how I approached it.
In your situation I have taken a tiny dot of hot glue and applied to the movement/dial side in two places. This is a controversial solution but it has worked for me.
Someday I'm going to learn to soldier feet in place since it happens often.
I wish I had a better solution. Good luck and let me know how it goes.
Regards
Hi Dial feet are easier than you think  look for a book by Wesley R Door on retro fitting , I build my own unit , not difficult comes under the heading of cold soldering using a spot arc at the solder point no harm to the dial.
Quoting this for future reference, thanks for the tip!
    • The original 6139A manual is very clear in how to disassemble and how to assemble ...... step-by-step. However I haven't seen the 3169B manual, even the Japanese version around, which clearly highlights the difference in center-wheel. Also, why the two different center-wheel reference numbers for the same caliber; 6139B? 6138A Seiko Technical Guide.pdf 6139_A.pdf 6139b.pdf 6138B.pdf
    • Hi as an addition a pertaining to the assembly of a 6319B  which will be handy for those working on this caliber Polly's 6139 guide.pdf 6139A.pdf 6139B.pdf
    • Casio MDV106G-1AV Gold DURO200 I'm going on a long family vacation to Southeast Asia this summer and wanted a cheap but reliable beater in case I lose it, break it, or get robbed. Quartz movements aren't my thing, but I'm not dogmatic and this was a cheap option. A few years ago you could buy it for under $50, but since this particular model with the Marlin fish has been discontinued, you have to pay about double that, but I still thought it was acceptable. Sure, I could wear one of my cheap and very reliable Vostok Amphibian divers watches, but I have a personal relationship with them (having put a lot of work into them) and don't want to risk losing them. Strangely, I feel very excited. Maybe because I haven't bought a brand-new watch in over 10 years! 😀 The only downside is that this is the watch Bill Gates has been seen wearing, and I'm not exactly a fanboy of Bill Gates. Anyway, who cares!?
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
