Crooked teeth
HectorLooi
I just took apart my Russian Navy clock for cleaning and to check why it was so loud. I discovered that the escapement platform had loosened and the meshing of the teeth of the 5th wheel to the pinion of the escape wheel had drifted. This resulted in damage to the 5th wheel.
Can I fix this by filing the teeth with a needle file? I don't know if there are replacement parts available for these clocks.
Looks like the contrate wheel. This is a hit or miss situation. You might get away by filing the teeth into shape, but you might also file away some depth, in which case you will need to alter the depth of the wheel, that then might stop the wheel because the depth will be too deep for the teeth that have not been affected. The best solution is to have a new wheel made.
Hi Hector I have seen videos of teeth being straightened up using a tool like a screw driver in the dwell and gently levering the tooth straight. II have done it myself on standard wheel but not a contrate wheel, In the end what have you got to loose if it works and I see no reason why not good, I not you will have to resort to a new wheel, In the end its your choice but I know what I would do     cheers
Contrate wheel.  I learned a new term today!      (So did the Linux spell checker)
I should hang out with you clock guys more often.  My Great Grandparents mantle clock calls to me when I walk past.  It runs.  Probably will never quit as the wife won't let me run it.  Sensitive and light sleeper, she is.
I should move it out here to the cave, but then I'd have to make a hole.
Thanks everyone. I'll try making a chisel-like tool to known the teeth back into shape 1st. If that doesn't work then I'll try filing. Last resort, I found a seller in Ukraine than has spare movement minus the escapement platform.
That is escaping a few teeth at a time. A good way of testing platforms to see if you have the correct depth is to test the complete movement in all positions, for at least a minute, that way you know the contrate wheel has made a complete turn, even test it upside down. I always did that with any platform clock, if all works well you know it will be OK and the depth is right. Always remember to check the screws are tight.
The parts are available for the Russian navy clock yours is marked up as a Smiths clock I presume that it is a copy using the Russian movement ?
If it is Russian the contrate wheels are available:
https://www.ebay.co.uk/itm/VOSTOK-Ersatzteil-FUR-RUSSISCHE-U-Boot-MARINE-SCHIFF-WANDUHR/254374795930?hash=item3b39eb5a9a:g:Cm4AAOSwEX1dkdpk
This would be a cheaper option than having a new one cut.
A friend gave me this clock. I didn't ask him where he got it from. It was a very badly put together frankenclock.
The original hinge of the brass casing was broken. An old cupboard hinge was used as a replacement. I don't think the case belongs to a Smith Enfield either. The hands are also a mismatch.
The bottom jewel of the escape wheel was also missing. The repairer put a blob of acrylic glue over the jewel seat and reamed a hole for the pivot. Managed to pass it off as an old clock that needed oiling.
I replaced the entire escapement platform as it was probably cheaper than trying to get a repacement jewel.
Thanks for the link. I'll try straightening the teeth 1st. If that doesn't work, I'll get the movement from Ukraine as my going barrel also has worn teeth.
I don't think my movement is a recent one. There appears to be a lot of wear. When I got the clock, the insides were drenched with a very thick oil. The trapped dirt did a lot of damage to the gear train.
It's just after midnight here in Singapore. 4th day of our lockdown.
I spent the evening straightening the teeth of the contrate wheel. I followed the advice of watchweasol and used a thick bladed screwdriver to wedge between every tooth and nudged them straight. Then filed the teeth a little to make them symmetrical.
Sorry I didn't take a final photo of the wheel. Didn't have the energy to take apart the clock again.
Thanks everyone for the help.
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
