Hallo there :)
ffar
Hallo everyone. My name is Maciej, 31 old. I am from Poland but at the moment I life in United Kingdom. And happened to become citizen of this country as well. It is pleasure to meet all of you.
I am not professional watchmaker or even an amator. However I do love watches and it amazed me how people are able to create amazing movements. It is an art. I have taste in good clothing, however I do not follow fashion, I am by my own. And I do finding watches as very, very important part of jewelry.
I do have quite some watch collection myself. Some of them are very cheep brands other bit more expensive(at least for my packet). But it does not matter for me if it is cheep or expensive, I do respect every watch I have and I keep it in boxes.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
