Munky From Germany Says Hello
Munky
Hi,  I am an American watchmaker and machinist set up for repair, restoration, modification and bottom-up manufacture living currently in Germany.  I have a penchant for vintage tools from German and Swiss and US manufacturers, and use Lorch, Boley, Bergeon, in tandem with modern machine equipment (CNC, mill, lathe, drill press, media blaster, etc.).    My repair and service work takes in a lot of luxury brands like Rolex, Patek, Audemars Piguet, Omega, Panerai, but I also replace batteries for cheap quartz watches, and have repaired cuckoo and kitchen clocks.    I have benefitted from watching Mark's wonderfully methodic and instructive videos on You Tube, which is what made me aware of this site.  You lot are a very civilized and polite bunch, and I look forward to interacting with you as soon as I get through my "lurker" phase.
