Munky From Germany Says Hello
Munky
Hi,  I am an American watchmaker and machinist set up for repair, restoration, modification and bottom-up manufacture living currently in Germany.  I have a penchant for vintage tools from German and Swiss and US manufacturers, and use Lorch, Boley, Bergeon, in tandem with modern machine equipment (CNC, mill, lathe, drill press, media blaster, etc.).    My repair and service work takes in a lot of luxury brands like Rolex, Patek, Audemars Piguet, Omega, Panerai, but I also replace batteries for cheap quartz watches, and have repaired cuckoo and kitchen clocks.    I have benefitted from watching Mark's wonderfully methodic and instructive videos on You Tube, which is what made me aware of this site.  You lot are a very civilized and polite bunch, and I look forward to interacting with you as soon as I get through my "lurker" phase.
    • It's pronounced "bombay" like the city.  French for bomb is, 😄, bombe, pronounced the same as in English. Bombé, bombe.
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
    • I have quite a few watch brands from all over the world. For some reason this Timex electric from 1979 is capturing my attention this week. I am not a particularly fond of battery operated watches or Timex, but this one is different for some reason. Post your watch in your collection that seems to draw you in more now than before...
