Hello from Norway
Bopmd
Hello!
I'm a 17 year old watch enthusiast from Norway. About 6 months ago i started taking apart watches and putting them back together. So far I've totaled more than 15 watches, but I've learned from my mistakes i hope. :)
    • Hello and welcome from Leeds.
