Movement 798.002
Anybody in the group know I can download a tech sheet on this movement?  In the process of disassembling this movement.......it runs but it’s losing time.............. l am learning by  taking apart cleaning and oiling and putting back tOgether certain movements.......
Hi with the takeover of the ebauches , and various other swiss watch companies By the SWATCH group the information on ETA watches is now getting harder to obtain unless you are a purchaser of their products.  The ETA tech data Base is now enclosed within that realm. Trade Only
The 978.001 is practicaly the same as the 978.002 and is an obselete movement.
I dont have the tech sheet for this but as it came in many shapes one could use a third party manual like this.
http://watchreserve.com/bulova-281010
Certina 133 is the same movement to
IMG_20200406_165435.thumb.jpg.2fe45979a16fa33e9a78fff8c97b2fa2.jpgo.
Or why not just replace it with this one.
https://www.esslinger.com/harley-ronda-2-hand-quartz-watch-movement-hq751e-hq978-o-a-3-7mm-to-replace-eta-978-002-and-eta-578-004/
The only downside is the dial is not always compatible with the Ronda movement.
Edited by HSL
Took a look at this mystery, it seems no tech sheets are availible for this one so the close match and recommended replacement seemed to be the 976.001, but there are quite obvious differences in these two movements so they are not 100% the same but really close. Found some specimens in the bin to show the differences.
As expected the 978.002 only shovs the mechanical outlines at ETA.
https://shopb2b.eta.ch/978-002.html
But for the 976.001 they have the whole techsheet shaboom.
https://shopb2b.eta.ch/976-001.html#description
https://shopb2b.eta.ch/976-001.html#technical-documents
So you probably have to go with the 976-001 for this one.
I found a ETA movement out of  Canada that sells the 978.001 movement for 78$... Thanks for the advice
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
