Russian Sub pannel clock
vinn3
I have a Frankenstein version of this clock. Someone put this Vostok movement into an English style brass casing and slapped on a Smiths clock face.
It had me stumped for awhile. Couldn't figure out what movement it was. I checked all internet photos for the trademark on the plates. Finally found out it was a Russian navy clock. Supposed to be used in their submarines.
It seems it was 1st made in 1948. I think they are still in production.
It's pretty accurate but really noisy. I'm sure you could locate the sub by the noise this clock makes with modern hydrophones.
