Victorinox 241321 stem crown?
Post a picture of the module to identify it. Then you can consider buy a replacement or take it apart to inspect and fix the keyless works. Check that you can still screw back stem to crown.
8 minutes ago, Merlynda said:
I didn’t understand any of that. The stem won’t screw together. Looks broke to me.
OK. Are you sure you want to take this by yourself? More expeditious would be to give or ship it to a watch repair shop.
Anyway, if the broken stem cannot be removed from the crown then both part will have to be replaced. And then check  that the stem is held in the module correctly.  Honestly all that is way beyonf the level a watch owner can do., The pic you posted is too poor to read the markings on the module. All in all, consider buying a new watch, this can probably be sold easily for parts on Ebay.
Hi as jdm remarked the picture is not good enough for us to identify the movment. If possible a closer and clearer picture will be of great help. Once the movement is identified we will be able to point you in the right direction regarding the stem, thanks
If I would make a dearing guess that is an ETA 251.474, you can read the exact model of the movement under the most right coil.*
Or as they suggest take a new picture...
It was almost the same as I thought, the stem for that is easy to get, since I live in Europe Cousine in UK is a great source, but there probably are places in the US to get it too, otherwise I probably have one at home.
A tip is to buy atleast two if you never changed a stem before because it is a little bit tricky to cut it to the right lenght, almost everyone here probably cut one too short sometime.
The next step will be to take a shot of the stem on the crown or if you could see inside of it, when the stems snapps there sometimes will be a short bit of the threads inside of it. If there still is a bit you could try to gently to remove it, otherwise you need to buy a new crown too.
Your in luck, now it is time to grabb the pliers. Turn the crown gently back and forth to see if it gets loose, if not the stem is glued and you need to apply some heat onto the stem stump, I usually use a welding gun but i asume you dont have any so if you just quickly warm the stem with a lighter it may do the trick. Never try to force it too much.
Since you got the stem out already I guess you figured that part by youself.
One can be sure there is no bit left in the mevement since the stem is a "snubbnose"..
So the risky part here is to get the stump out from the crown, otherwise you already done the hard part.. getting the stem out..
Edited by HSL
Unfortunately I think you managed to break it a bit more, one have to be very carefull, there still is a bit left to grab on.
The end result should look little like this..
I saw i previously wrote welding gun, of course I mean soldering gun, sometimes I get other things mixed up while I make myself a Gin & Tonic..
1 hour ago, Merlynda said:
looking for a crown
Cousins UK has the largest and better described offer.
Again I recommend that you try well if the stem stump is held and works in the module otherwise the fault problem does not end with stem and crown.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
