Safe separation of wheels
Hello,
I’m currently working on a vintage Cortébert 677S movement. During strip down I came across a wheel pivot tightly friction fitted through the train bridge to another on the underside. It reminded me of some Smiths double wheel assemblies but obviously these are supposed to be separated to clean the jewel holes and lubricate. I’m sure given the right amount of pressure they’ll separate. I’m guessing the friction fitting is similar to a centre wheel through a canon pinion. Does anyone have any advice on tackling this safely without risking damage to any of the components? Photos of issue shown.
Thanks!
When I read your subject title I thought this was going to be something to do with social distancing!!!  :D
The wheel on the top of the plate (which drives the center seconds pinion) is a friction fit onto an extended pinion that comes through the plate, a bit like a sub second pinion goes through the main plate.
There is a specific Presto style remover (mine is Bergeon 30638/3) for removing this wheel but it can be done with levers or even razor blades. The key thing is to ensure that the wheel is lifted vertically so that there is absolutely no bending force on the pinion as it is very brittle and easy to break, otherwise it should be relatively easy to remove.
Reassembly is also easy, especially if you have a staking set.
 I agree with Marc use a presto tool specific for this job. Looking at your pics measure before and lift the wheel from the underside (would be best if poss) so as not to distort the other wheel. The key to this job is a very straight lift. Also when re-stalling a straight push putting the wheels to the same positions on the arbour .
Thanks for all your quick responses.
Nucejoe, I’m just concerned that by not separating, I’m unable to easily lubricate the jewel holes after cleaning. However, I don’t have a presto tool (I have an old Star No.230 tool I use instead). Maybe an excuse to buy the required tool though!
Thanks!
9 minutes ago, Nucejoe said:
With all due respect to both gentleman above.I just clean in place, these independently driven minute wheels and save yourself a headache. Regards
Tempting, I  must admit Joe especially if you do not have the correct tools. However checking to see if the pivot is scored will not be possible so I would remove.
If you decide to buy the presto type tool then be aware there are 2 variants - one for 5 spokes and one for 6
https://www.cousinsuk.com/category/train-wheel-removing-tools
They are quite expensive if you buy new. I got mine second hand, but before I had them I did this successfully with a pair of knife blades inserted under the hub of the wheel.
Thanks for sharing your thoughts Stuart. I went ahead and bought the 5 spokes version from Cousins based on Marc’s suggestion earlier in this thread. What I’m saving on not going out at weekends has paid for that! Hopefully it will arrive today/tomorrow and I’ll look forward to giving it a go. Will also be a useful tool to add to my slowly growing arsenal.
Cheers!
Just to complete this post, I'm pleased to say that the Bergeon Presto 30638-3 tool I bought worked a treat (photos to illustrate). The movement has now been cleaned, lubricated, and is in working order. I particularly found the BHI paper on the 'Practical lubrication of clocks and watches' interesting and have decided to swap my Moebius D5 oil for Moebius HP 1300 synthetic.
Thanks to everybody that contributed. oil.20200403_225709952_iOS.thumb.jpg.0923e91745364eab9b84dac15951fbd2.jpg
Edited by AdamC
    • As an experiment i was thinking of not hardening it to see how it fairs. Now that i have a complete template i could knock up another in half the time if this loses its elasticity. I might play about with a few pieces today to test their bending and spring properties. This was cs 100 the supplier quoted in annealed state, it was nice to work with files so I'm taking it thats its state. What you are looking seems like it would need annealing to work it. This is why i went for this stuff that cuts out that process, it was so easy to work.
    • Showing state of hairspring on receipt, backplate & 'dished' wheel.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?       Have you seen this video, he shows how to determine where the indents go ?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
