Omega Trench Watch 1914-1918
Hello everyone,
My name is Julian and I am new to the forum and new to the hobby of watch repair (although I would not call myself a watch repairer!). I have been trying to read and research my way to being able to repair pocket watch movements as a starting point, so bear with me if anything I say is incorrect. I'm happy to have a forum like this to get the advice of people much more knowledgeable and skilled than myself. Anyways, enough of the introduction, let me explain what I have.
I recently been given an old Omega Trench watch. The watch has certainly seen better days (see attached movement photo). Based on the serial #, the watch is approximately from 1914-1918. The case is likely silver nickel due to the absence of any hallmarks. The dial has a few faint cracks but nothing of major concern. The hand are oxidized and I am considering replacement or refinishing. The movement appears to have rust on many parts of the train. Before I take things apart (waiting on the appropriate tools), is there anything that can be done about the 3rd and 4th wheel or will they need to be replaced?
Worst-case scenario, if I recall, these movements are the same as early Omega Ladie's pocket watches and they could be used as a donor movement?
Thanks for any help/information that can be provided,
Julain
Hi  There is a fair amount of filth around and the ratchet wheel and intermediate wheel are a bit grotty, but, If you have a screw driver, First led down the power on the mainspring then remove the wheels and dunk them in coke or vinegar for a few mins then brush repeat as required you will be able to clean them up abit,  Once you get hold of the tools then work will commence.  It looks a nice little watch, definitly worth a go for sure       watch first released around 1910..
Thanks! I’m glad to hear this may be salvageable. It’s 35mm for those who are wondering. Hopefully none of the screws are rusted to the point where they are seized.
2 hours ago, rodabod said:
I would leave the hands as-is unless you are skilled and blueing.
I will definitely leave the originals as-is but I may use replacement that are less oxidized. Not sure where to source the proper size though. Blueing is a skill that is far away for me haha.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
