omega 565
Ihey
I know this is a long shot but anyone know were i can get a glass/crystal for a omega cal 565 case number 166.026.
It don't need to be by omega just as long as it fits. I have tried measuring the size i need but i keep getting different sum.
used. is fine.
yer don't ask yer don't get
cheers guys
gary
Somewhere in the universe there should be a cross reference guide for Omega that explains how you're supposed to modify the numbers to find things. So as noted above by canthus I have more or less the same link below. Then with the crystal number I found some additional specifications for the crystal. Also found another seller selling the crystal at the second link..
063PZ5315 | GLASS PLEXI ST RING
GLASS PLEXI ST RING
REF :063PZ5315
063 DIAMETER D1 :29.62 MM
063 EYEGLASS :WIHTOUT
063 HEIGHT TOTAL H1 :3.60 MM
063 PROFILE :CONCAVE
063 SHAPE :ROUND
063 TYPE :ETANCHE
http://www.ofrei.com/page_168.html
https://timeconnectioninc.com/crystals/2329-omega-crystal-063pz5315.html
I apologize for the second link I had casually look to make sure I thought they would sell to the general public. Especially if there selling out estate tax things shouldn't be an issue. I know locally one of the material houses I do business with she will sell tools to individuals because she collects tax from everybody then on the matériel you have to have a reseller license or business license or something. But you're right I went through their fact thing and their very clearly wholesale.
You do have to be careful on eBay because when I initially search for the number they suggested all sorts of happy answers of crystals that didn't exactly have the right number some make sure these actually really are the right number. The Poland one is cheaper but they charge shipping and who knows how long it takes for things to travel now if it travels at all.
The first link looks promising and they claim it's in stock?
https://www.cousinsuk.com/search?SearchTerm=PZ5315
https://www.ebay.com/itm/OMEGA-CRYSTAL-29-60mm-PZ5315-166-0257-166-0258-166-0259-166-0260/163304969306?hash=item2605bc145a:g:z8cAAOSwpLNX79w5
https://www.ebay.com/itm/Omega-Plexiglass-Crystal-with-Steel-Tension-Ring-Part-Number-PZ5315/122320971295?hash=item1c7ae5e61f:g:bgMAAOSwjDZYg86U
hey
glass came today its 1 mmout by my calc.
The glass that came is 29.8mm and it needs to be 30.8 mm so john if you have that page were you got the 29.8mm one from i may be able to order next size up.
This might finally answer the question about omega and there coding.
Any way thanks very much everyone who helped.
its much appreciated.
cheers
gary
It appears to be that it would've been helpful if we had paid attention to a prior discussion found here?
https://www.watchrepairtalk.com/topic/13746-166026-omega-case/#comment-122709
So the very last reply by StuartBaker104 Has what I think is the solution to the problem. If you enter the case number in a variety of databases the decimal point isn't really a decimal point is just a separator and you need four digits. If you don't specify What the fourth digit is the various databases will fill in a number. So we had assumed that case number 166.026 was the same as 166.0260 just because we found parts for it but it is obviously not the correct case number. So for instance in the above discussion I found a link to Omega with the case number but we weren't paying attention because the movement was wrong and of course they filled in the fourth digit which is also wrong. So if you go to Omega with what we perceive is the correct case number we get the following link which seems to have the right movement?
https://www.omegawatches.com/en-us/watch-omega-seamaster-cosmic-st-166-0026
The only problem is the dimensions do not appear to be correct for the crystal?
063PX5123
GLASS PLEXI 2N RING D32.94 H4.9
REF :063PX5123
063 DIAMETER D1 :32.94 MM
063 HEIGHT TOTAL H1 :4.90 MM
063 SHAPE :ROUND
063 TYPE :UNICOQUE
DIAM OF THE GLASS SEATING D2 :32.80 MM
Here I am!
I would agree with you John. I also trust Archer in this thread... https://omegaforums.net/threads/seamaster-cosmic-replacement-crystal.31678/
He has access to the Omega parts database and I’ve learned a lot from his posts.
It seems odd that your measurement is so far out Gary.  Can you post a photo of the case markings?
I think the markings look fine compared to other photos on the interwebs, and there is no doubt about the case number. Also no doubt that PZ5123 is the listed part for this case.
Cousins has the old Sternkreuz R19 catalogue scanned on its site. Page 163 lists their Omega equivalents, but there is nothing in the 30.8 range, to help find an Omega part number: https://www.cousinsuk.com/document/category/watch-glasses
PZ5123 equivalent is listed as XAC 330.553 which are about £6-7.
There is a wealth of other information in this catalogue about sizing and fitting glasses which is useful.
If you are certain this needs a 30.8 crystal, then I think you will need to buy the closest match you can find to the installed one (see page 50 of the above).
The only other thing I can think is that you aren't measuring it right... what are you using for that?
It's a vernier I think but it's a cheap one. A sliding ruler type thing 2 point. 1 point on 1 side other opposite side.
Tried it on crystals I know the size of and it's onlt been 0.1mm out on 6 crystals. Sorry if I am late answering I am thinking of buying a omega seamaster professional 300m james bond automatic it's a 2004 model Ltd edition I can have it for 1500 pound all papers and box and all service receipts.so been. A bit sidetracked
Newer version of the catalog with less pages?
http://www.sternkreuz.com/accordion/assets/Sternkreuz_Gesamtkatalog G22.pdf
Fresh day brings fresh thinking...
These monobloc cases have an Omega crystal removal tool reference on the back, which tells you the size of the crystal. Found this table
101/2042
102/2242
103/2492
104/2995
105/3095
106/3195
107/3295
So tool 107 would be for a 32.95mm crystal.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
