omega 565
Ihey
I know this is a long shot but anyone know were i can get a glass/crystal for a omega cal 565 case number 166.026.
It don't need to be by omega just as long as it fits. I have tried measuring the size i need but i keep getting different sum.
used. is fine.
yer don't ask yer don't get
cheers guys
gary
Somewhere in the universe there should be a cross reference guide for Omega that explains how you're supposed to modify the numbers to find things. So as noted above by canthus I have more or less the same link below. Then with the crystal number I found some additional specifications for the crystal. Also found another seller selling the crystal at the second link..
063PZ5315 | GLASS PLEXI ST RING
GLASS PLEXI ST RING
REF :063PZ5315
063 DIAMETER D1 :29.62 MM
063 EYEGLASS :WIHTOUT
063 HEIGHT TOTAL H1 :3.60 MM
063 PROFILE :CONCAVE
063 SHAPE :ROUND
063 TYPE :ETANCHE
http://www.ofrei.com/page_168.html
https://timeconnectioninc.com/crystals/2329-omega-crystal-063pz5315.html
I apologize for the second link I had casually look to make sure I thought they would sell to the general public. Especially if there selling out estate tax things shouldn't be an issue. I know locally one of the material houses I do business with she will sell tools to individuals because she collects tax from everybody then on the matériel you have to have a reseller license or business license or something. But you're right I went through their fact thing and their very clearly wholesale.
You do have to be careful on eBay because when I initially search for the number they suggested all sorts of happy answers of crystals that didn't exactly have the right number some make sure these actually really are the right number. The Poland one is cheaper but they charge shipping and who knows how long it takes for things to travel now if it travels at all.
The first link looks promising and they claim it's in stock?
https://www.cousinsuk.com/search?SearchTerm=PZ5315
https://www.ebay.com/itm/OMEGA-CRYSTAL-29-60mm-PZ5315-166-0257-166-0258-166-0259-166-0260/163304969306?hash=item2605bc145a:g:z8cAAOSwpLNX79w5
https://www.ebay.com/itm/Omega-Plexiglass-Crystal-with-Steel-Tension-Ring-Part-Number-PZ5315/122320971295?hash=item1c7ae5e61f:g:bgMAAOSwjDZYg86U
hey
glass came today its 1 mmout by my calc.
The glass that came is 29.8mm and it needs to be 30.8 mm so john if you have that page were you got the 29.8mm one from i may be able to order next size up.
This might finally answer the question about omega and there coding.
Any way thanks very much everyone who helped.
its much appreciated.
cheers
gary
It appears to be that it would've been helpful if we had paid attention to a prior discussion found here?
https://www.watchrepairtalk.com/topic/13746-166026-omega-case/#comment-122709
So the very last reply by StuartBaker104 Has what I think is the solution to the problem. If you enter the case number in a variety of databases the decimal point isn't really a decimal point is just a separator and you need four digits. If you don't specify What the fourth digit is the various databases will fill in a number. So we had assumed that case number 166.026 was the same as 166.0260 just because we found parts for it but it is obviously not the correct case number. So for instance in the above discussion I found a link to Omega with the case number but we weren't paying attention because the movement was wrong and of course they filled in the fourth digit which is also wrong. So if you go to Omega with what we perceive is the correct case number we get the following link which seems to have the right movement?
https://www.omegawatches.com/en-us/watch-omega-seamaster-cosmic-st-166-0026
The only problem is the dimensions do not appear to be correct for the crystal?
063PX5123
GLASS PLEXI 2N RING D32.94 H4.9
REF :063PX5123
063 DIAMETER D1 :32.94 MM
063 HEIGHT TOTAL H1 :4.90 MM
063 SHAPE :ROUND
063 TYPE :UNICOQUE
DIAM OF THE GLASS SEATING D2 :32.80 MM
Here I am!
I would agree with you John. I also trust Archer in this thread... https://omegaforums.net/threads/seamaster-cosmic-replacement-crystal.31678/
He has access to the Omega parts database and I’ve learned a lot from his posts.
It seems odd that your measurement is so far out Gary.  Can you post a photo of the case markings?
I think the markings look fine compared to other photos on the interwebs, and there is no doubt about the case number. Also no doubt that PZ5123 is the listed part for this case.
Cousins has the old Sternkreuz R19 catalogue scanned on its site. Page 163 lists their Omega equivalents, but there is nothing in the 30.8 range, to help find an Omega part number: https://www.cousinsuk.com/document/category/watch-glasses
PZ5123 equivalent is listed as XAC 330.553 which are about £6-7.
There is a wealth of other information in this catalogue about sizing and fitting glasses which is useful.
If you are certain this needs a 30.8 crystal, then I think you will need to buy the closest match you can find to the installed one (see page 50 of the above).
The only other thing I can think is that you aren't measuring it right... what are you using for that?
It's a vernier I think but it's a cheap one. A sliding ruler type thing 2 point. 1 point on 1 side other opposite side.
Tried it on crystals I know the size of and it's onlt been 0.1mm out on 6 crystals. Sorry if I am late answering I am thinking of buying a omega seamaster professional 300m james bond automatic it's a 2004 model Ltd edition I can have it for 1500 pound all papers and box and all service receipts.so been. A bit sidetracked
Newer version of the catalog with less pages?
http://www.sternkreuz.com/accordion/assets/Sternkreuz_Gesamtkatalog G22.pdf
Fresh day brings fresh thinking...
These monobloc cases have an Omega crystal removal tool reference on the back, which tells you the size of the crystal. Found this table
101/2042
102/2242
103/2492
104/2995
105/3095
106/3195
107/3295
So tool 107 would be for a 32.95mm crystal.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
