TISSOT SEASTAR 1970'S 2481 MVMT
Hello. I bought a 1970's Tissot Seastar automatic cal 2481 mvmt on Ebay .Before i bring this to my watch repair man i was hoping you might have an idea what is wrong from how i have described it.. when you go to set the time it will click once an hour like there is a tooth issue in the setting train. It will set fine but it has that clicking issue.
I suppose its service history is unknown, it could be even that is has never been serviced and getting close to 50 years now. Bring it to your repair shop with confidence, they will telly exactly what it is and provide an estimate.
Thanks. Watchmaker heal my seastar please.
30 minutes ago, watchweasol said:
as jdm remarked, the fact its service history is an un known quantity one can only guess, could be a problem with the keyless work skipping.  I dare say your watchmaker will tell you for sure and a good service will be in order.
Yes...needs a professional eye. Thanks for the reply.
Your own diagnosis gets my vote. "An issue in set train" You can produce more data, make a note of the min it clicks, repeat to make sure of it's consistency. Turn anticlock to set time, make note of the min it clicks. If the click shifts to a different min, it's friction exasperat fault, if it is at the same min, a broken teeth. The teeth could have been damaged during service a day before it went on sale.
hello. it clicks slightly further ahead each time you go around the hour. what is a friction exasperate fault and is it costly to fix please
What you describe sounds like a typical fault on these movements, the 2481 has a push quick set.
Very often the spring which supplies the tesion to the setting lever brakes of and the result becomes exactly what you describe.
Sometimes someone has pushed the lever to hard and the result is a bent setting lever. BentSettingLever.thumb.png.64e7fd3f91dde6bf2d4c1ddafb28d374.png
I sometimes seen the attemt to fix the fault with a setting lever from a standard 2851, but that will not work very well since it has no datefunction and therefor has a slightly different design.
The cost for a fix varies but it is probably a movement which is obselete and identical to the Omega 1481 so the repair might not be so cheap.
thank you for the education. it is so greatly appreciated. you are right the push date function does not work so it sounds like you have diagnosed it right. I will bring it in to my watchmaker and have it repaired. would you know what type of band this would have had. this band is not original and does not fit anyway.
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
