seiko 1582
Hey guys
Working on this seiko cal 1582 its a automatic but i wanted it to wind by hand as well. Is this possible?
Please check pics
!st photo show the keyless gear set correct to wind manual.
2nd i add bridge to hold in position.
3rd after i pull stem to move to hand setting position
4th check position of clutch and setting pointer (the thing that moves the clutch lever)
5th i push stem back in to winding position check position of pointy thing and clutch this is not right to wind.
6th arrow pointing down is at the notch it needs to be in for me to wind it.
stem will not go in any further, the only way i can get it in the notch is by forcing it there by hand.
Any suggestions of were i am going wrong?
cheers
gary
This movement partly reminds me of an ORIENT calibre I'm just servicing and it can't be wound manually. Wouldn't a winding pinion be a requirement for manual winding? Can't see any in your pictures. :unsure: Still, the clutch wheel sort of looks like it is designed for a winding pinion?
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
