Ansonia Clock
Burntrees
Called a crystal or four glass clock. It could be an 8 day duration and it’s a strike on a gong. Pendulum is called a girl on a swing.  Watchweasol is correct in saying the case is spelter, so be very careful as this stuff breaks and its very difficult to repair. Dates around the 1900’s to about 1915. Value to sell as I see it about £1,000
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
