  • Similar Content
    • By Misshollypocket
      I actually have a couple problems I could use some help with. I’ll start with the more serious one I guess. I don’t have any trouble getting the back off my watches or changing the battery, but every time I use my tool to snap the back back on, something happens to the crown pin. It just lets go and comes out. I thought it was a strange occurrence the first time but I tried another one this week and got the same results. I’ve done this same thing on hundreds of other watches of different types and brands but never ran into this problem before. Can someone please help me figure out what I’m doing wrong?
      Also, a couple of my watches don’t seem to be able to adjust to my teeny tiny wrist size. In my Monarch, the majority of the links don’t have holes to remove the pins. Is there any other way to remove a couple links. Any advice would be appreciated immensely!!!
    • By Trevelyan
      Hi, new to repairing, just getting my feet wet, so be prepared for me to use incorrect language, and have things explained like I'm 5 :)
      A couple years ago, I purchased a Seiko Sportsmatic Weekdater, cal. 6619-7050.
      Soon after purchase, the crown detached from the stem, and I took it in to local watchmaker for repair. It was returned in apparently good shape, but actually the problem still exists.
      I'd like to learn how to fix the problem, and hopefully bring this watch back to my wrist.
      It appears that the crown screws onto the stem, but that is as far as I have got.
      Any assistance would be welcomed. I did find a service manual elsewhere, but I'm a bit lost as it's my first.
      Seiko Sportmatic 6619A.pdf
    • By Furqan
      Hello Everyone.
      I need some help with repairing my Emporio Armani ar-1922.
      I've watched some videos on YouTube but none of them resemble the movement of this particular watch.
      My first problem is removing the stem/crown. I cannot see anything which looks like it will release the stem and I don't want to poke around inside it any more for fear of creating any damage.
      Any help will be much appreciated.
      Thanks.
    • By Joshua
      Hey, so I have a question. I've got an Invicta dive watch with a NH35A movement here that whenever I unthread the stem and crown as it is unthreading the date starts changing. Once its unthreaded I can change it to the 1, 2 and 3 positions and set and wind it accordingly. How can I fix this and what is causing this?
      Yours truly, Josh
    • By Lorenz
      Hey guys, my name is Lorenz. I am an 18 year old electrical engineering student from Germany.
      I got this Breitling chronospace a56012.1 from my granddad and I want to repair it.
      Besides a slight clicking noise while turning the crown ( someone please let me know if this is normal ) it works just fine.
      My main problem is that the black color on the Bezel is worn out on some positions and I dont know where to find a paint that holds on the metal nor do I know how to paint it again.
      I have worked with watches already, I disassembled a mechanical movement cleaned and oiled it again so I feel pretty confident in doing this job.
      And I would also like to change out the crystal, does anyone know what size crystal I need for this watch?
      Thanks in regards for any advice.
    • Ok, I got it to work.  It was together correctly.  HSLs pictures helped.  I didn't realize there was a third position.  It just requires an alarming amount of pull to get it into that position. Thanks all Charlie
    • Another came in over lunch! This one is even running! A. Schild movement. Gold case with some damage, but the damage suggests it's at least not plated. Dial is in good shape. Not a bad score for €3,50!
    • I had the same problem with the lyre spring on my 6497 clone... Flew off 3 or 4 times... but luckily found it each time. Good tip about the plastic bag @watchweasol! I may well go with that in future. Lyre springs are turning into my pet hate already. I broke a tiny one on the first practice watch I got to work on (FHF ST 96) barely touched the arm and snapped clear off... it was about the last thing I was doing after a full clean and reassembly too... I ordered a new one (not that it is economically worth it, the watch cost £1.70) but I didn't want to leave it unfinished now I had gone so far, with the particular lower shock setting the movement has it will give me practice removing and replacing the setting too.
    • The AS 2066 seems to be a quircky one took some photos of the setting positions. As you see on the third picture the day is connected to the hour wheel, so every 24 hour it flips it. But the date has a quick leaver in the second position. When the lever spring isn't level or tight enough this causes the quick date set to not function. Winding position.   Quick date. Time and Date.
