hi,i am currently working on a AS 1913.All the wheels are spinning freely.the problem is when i pull out the stem to operate the hand function everything turns,including the mainspring barrel.when i push it back in the crown wheel engages and turns everything again.when i release the click to let the power down nothing happens.i have checked the keyless works and everything moves up and down as it should.am i missing something.i have tried using a different barrel (same model) but to no avail.any ideas please.B
Sounds to me like the pallet fork is not interrupting the escape wheel.
This would mean that as you wound the watch everything would spin, and no power would be retained in the main spring, so nothing would happen when you tried to let down the main spring.
When you have the crown in the setting position the canon pinion has enough drag to also transmit torque back into the train, so once again everything would spin.
6 hours ago, AndyHull said:
Sounds like   the keyless work. Does the clutch engage and disengage when the crown is pulled?
Is the stem the correct one for the movement?
Can you provide better pictures of the keyless work in both positions?
it is the right stem.tried a spare i had.same result THANKS. B.IMG_20200321_142109.thumb.jpg.913b764146f44eae7c54ff0a5d793724.jpgIMG_20200321_142100.thumb.jpg.8134047c4d0205bbcc07879ad37020d6.jpg
Edited by berniethebolt
missed out my thanks!
i get that.will try again with the pallet fork.thanks.B
You have a little special construction on this movement . With a friction drive on the intermediate wheel . Instead of a normal cannon pinion. Should think that is why it moves the barrel to . Put the pallet fork in.  Or the automatic bridge.
This wheel turns the barrel . And has a friction like a cannon pinion. IMG_20200321_142100.thumb.jpg.8134047c4d0205bbcc07879ad37020d6_LI.jpg.02fff15583a9a95805f5d576322b6a94.jpg
A normal canon pinion would move things too, but good catch. That micro canon pinion should be disassembled and greased like any canon pinion though. All things said, with pallet fork out, setting time or winding will have a similar effect if the fork is out.
thanks to all.i have now got the movement going.thanks again.B
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
