hi,i am currently working on a AS 1913.All the wheels are spinning freely.the problem is when i pull out the stem to operate the hand function everything turns,including the mainspring barrel.when i push it back in the crown wheel engages and turns everything again.when i release the click to let the power down nothing happens.i have checked the keyless works and everything moves up and down as it should.am i missing something.i have tried using a different barrel (same model) but to no avail.any ideas please.B
Sounds to me like the pallet fork is not interrupting the escape wheel.
This would mean that as you wound the watch everything would spin, and no power would be retained in the main spring, so nothing would happen when you tried to let down the main spring.
When you have the crown in the setting position the canon pinion has enough drag to also transmit torque back into the train, so once again everything would spin.
6 hours ago, AndyHull said:
Sounds like   the keyless work. Does the clutch engage and disengage when the crown is pulled?
Is the stem the correct one for the movement?
Can you provide better pictures of the keyless work in both positions?
it is the right stem.tried a spare i had.same result THANKS. B.IMG_20200321_142109.thumb.jpg.913b764146f44eae7c54ff0a5d793724.jpgIMG_20200321_142100.thumb.jpg.8134047c4d0205bbcc07879ad37020d6.jpg
Edited by berniethebolt
missed out my thanks!
i get that.will try again with the pallet fork.thanks.B
You have a little special construction on this movement . With a friction drive on the intermediate wheel . Instead of a normal cannon pinion. Should think that is why it moves the barrel to . Put the pallet fork in.  Or the automatic bridge.
This wheel turns the barrel . And has a friction like a cannon pinion. IMG_20200321_142100.thumb.jpg.8134047c4d0205bbcc07879ad37020d6_LI.jpg.02fff15583a9a95805f5d576322b6a94.jpg
A normal canon pinion would move things too, but good catch. That micro canon pinion should be disassembled and greased like any canon pinion though. All things said, with pallet fork out, setting time or winding will have a similar effect if the fork is out.
thanks to all.i have now got the movement going.thanks again.B
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
