Chronograph hand loose
The centre sweeping hand has become loose on my watch. It’s a Chinese clone movement and there are no spares available unfortunately.
Where the hand attaches to the post is nice and tight. The problem is with the construction of the hand itself. I’m sure you guys know how these are put together but for anyone that doesn’t know, the hand is made of two parts the post and the part that rotates around the dial.
Looks like these two parts are just pressed together. This connection between the two parts has become loose, so when you reset the hand it won’t return to 12 (sometimes a few ticks off, sometimes 1 etc).
Ive tried using super glue and two part epoxy to hold the parts together but it hasn’t been successful.
Does anyone have any suggestions?
Thanks.
so if these hands were staked (riveted) together and now that part is loose. That indicates to me the part is damaged and the hole is probably worn so too big for the post part (I may be completely wrong here?). If it is damaged/worn is it possible to stake them together again?
Thank you for helping, I’m learning all the time here.
In a lot of cases re-staking is possible. If you don't have a staking set a crude method with thumbtack I've tried before worked for me:
Fit the tube back into the hole and have it stand upright, and then tap the tip of the thumbtack into the hole. Make sure to start with light taps and check progress under magnification as to ensure you don't split the tube. You just want a bit of expansion of the tube where it fits into the hand. Also make sure to do it on a hard surface so it doesn't absorb any of the impact and have the tube driven into it.
Also consider filing the tip of the thumbtack to put some facets to it. This will make the rivet irregular and stands to have less of a chance of slippage at reset than a perfectly round rivet. Although the one time I tried the thumbtack I didn't bother with this and the subject watch hasn't given me any problems yet.
Edited by CaptCalvin
I do actually have a K&D staking set (I have a bit of an obsession collecting tools), not sure if I have all the correct parts to do this repair though. Unfortunately I  have no idea how to perform this task though. I’ve checked YouTube and can’t find anyone doing this. Would love to give it a go though if you guys have the time to run me through it :-)
here is a video of what is happening
So using the thumbtack method I could keep the hand tight  in the collet (as seen in the video)and knock the tack from the top? This would force the Pipe part of the hand to expand slightly inside, hopefully gripping the hand.
is the method the same with a staking set? Knock into it from the top?
Edited by AP1875
Does the tube have a lip around it to support the hand as in the first picture or just a straight tube with the top turned down to fit into the hand? The straight tube type would be a little more challenging.
Do you know how to use a staking set? I dont have a staking set on hand at the moment but I would start with the sharper punches and progressively move through blunter and blunter punches until the rivet is nicely rounded and peened over.
A big issue with staking or restaking tubes like this is distortion of the tube itself. I've made up stumps with a hole diameter ever so slightly bigger than the tube, depth ever so slightly less than the length, so I can rerivett the darn thing without bending or otherwise deforming it. They can be a real bear.
Ok so it looks like the hand in question is the type that’s ‘easier’ to work with
5DC677FD-EEF4-439F-826A-401922E42A21.thumb.jpeg.beba68878d963cbd2d484ece2371ffea.jpeg3D0E7706-6E3E-4A01-8DEC-EA90123C6F7C.thumb.jpeg.235272c3e564f119390118ba576424f4.jpeg
only issue now is I don’t really know what the procedure is.
This is the tool I have, it came with a K&D box with quite a few bits. I was told I’d need a staking set at some point so hopefully this works out. Any direction greatly appreciated.
Reason why these are easier to fix is because they can simply be set into a hole in the staking contraption and not fall through.
1) Find the smallest hole on the platform that the tube will fit in.
2) Loosen knob behind contraption.
3) Insert centering punch (sharpest pointed).
4) Rotate platform and drive centering punch into selected hole.
5) Tighten knob. This ensures whatever punch you're going to use is aligned with hole.
6) Insert tube into hole and fit hand on the tube.
7) You're going to have to judge for yourself which punches to use here. Start with the sharper punches and work your way towards blunter punches. The idea here is you want to expand the tube so that it grips the hand, and you'll also want the top of the tube to curl outwards and over. Sharper punches are more efficient at the expanding, and blunter punches will do the curling. Don't get aggressive with the sharp punches and go too deep and split the tube.
But really it would be nice if a someone with actual experience chimes in. I haven't yet touched a staking set (poor college kid). This is just a procedure I've thought up in my head with knowledge accumulated through books and internet. Try it if it makes sense to you haha. :startle:
16 minutes ago, Hondadoug said:
I think in this case a small flat punch is all that is needed to flatten the rolled portion and restore the crimp. Don’t over think this  it is just a very simple basic repair. Make sure your anvil supports the lower flange .
Starting with a flat punch would be smart actually. Chances are that's all you need. And if it doesn't work then you can try the pointed punches. Flat punches are more forgiving so not a lot of harm done as opposed to trying the pointed punches first thing and whacking it a bit too hard.
Ok so I put the hand in the base like this?
I will then line up the base with a stake, so a flat stake can sit directly on the hand (I will use some plastic wrap to protect it)
the idea is to use the force from the stake on the top of the hand and hopefully it will cause it to expand gripping the hand.
Did I understand that correctly? I just want to make sure I’m doing this correctly because it looks like I’ll only get one shot at it. Thanks
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
