Scuffed my bracelet, how to repair
Hi guys,
ive scuffed my bracelet, no idea how but I’d like to try and salvage it if possible. Can anyone help advise what the process is? On the polished bits I’ve always used cape cod to good effect, not sure how to work on these brushed parts though.
1 hour ago, AP1875 said:
I have a few links with scratches and dents, the scratches will come out with cape cod but when it’s a little deeper like this what is used?
Buff it first with rotary tool, a 5cm hard felt wheel and Dialux Orange works great. If you want it shine then polish with Dialux Blue, otherwise if it's a brushed purchase go directly to the green pad. There are also different grain pads for a finer finish.
 Thanks for the info JDM. As you can probably tell this is a side of the watchmaking/restoring hobby i'm just starting to venture into. It does really interest me though. I'm going to buy some cheap bracelets from cousins scratch them up and see if i can get them looking 'new' again before i cause this bracelet anymore damage.
So, for the 5cm felt wheel would this be ok
https://www.cousinsuk.com/product/050-to-0150mm-felt-wheels-made-in-uk
Dialux orange and blue
https://www.cousinsuk.com/product/dialux-rouges
Any suggestions on a rotary tool?
Thank you
Much better is to buy beaten up SS watches on Ebay. Restoring is not difficult, and very rewarding.
Quote
Even cheap Chinese are OK. What you want is good mandrels for the wheels, also great is a support for the tool.
Edited by jdm
Not really sure where to begin with selecting this type of tool but I guess my first question should be is this the type of tool required?
https://www.cousinsuk.com/product/cousins-polishing-motor
That is a motor as I have, beside that you can get it for much less on AliX, rotary tool means something  hand held like a Dremel, Proxxon to mention brand names, but even a Chinese no name is OK, or a drill on an improvised support. Results mostly depend by case in question and technique, if you only have to restore you few pieces it's pointless to spend much. Get also smaller wheels as it's easier to do precise work and avoid edges.
Edited by jdm
3 minutes ago, AP1875 said:
I do actually have a Dremel. It’s a rechargeable one.
https://www.dremeleurope.com/gb/en/dremel®micro-898-ocs-p/
I guess I need a bracket to mount it to a desk and something to hold the hard felt wheel.
Hopefully Dremel make both of these attachments.
Small repairs like the above can easily be done hand held. It's when working of deep dings or large areas (bracelet clasp are surprisingly time consuming) that a motor or a bracket really becomes really a saver. Don't forget to wear cotton gloves and work inside a cardboard box because is a bit of messy work.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
