H/S centering problem
Hi all,
Struggling with a h/s problem that I can’t get my head around.
The movement is a Tavannes 38 that belongs to an old (30’s?) art deco tank watch. I have serviced the movement and at first (well after some tinkering in the h/s area) it ran beautifully with good amplitude and nice straight lines on the timegrapher.
But then it started to behave weird, speeding heavily and stopping.
I had noticed that the first h/s turn outside the regulator runs very close to the regulator pin and this is where I had pushed and pulled a bit to get it to run free. Which apparently worked for a while....
Removing the h/s from the balance wheel and mounting it back on the bridge, I seem to find that the h/s (in my eyes) looks quite decent with overall evenly spaced turns etc.
But the collet is clearly offset and centering it will inevitably push the turns tighter and closer to the regulator pin.
With my limited h/s adjustment experience, I can’t see a way to move the collet to the correct position without, in some way, influencing the overall h/s shape and possibly create unwanted touching between h/s turns or the regulator pin.
A photo is attached. I hope it makes sense to explain my problem.
Hi as mentioned the B/s is not right , The spring between the regulator and the stud is a little out of concentricity,  The arc should allow the regulator to move round without touching the spring and be centered between the pins. If you move the regulator towards the stud the collet will move from the center. Ideally you want the collet centered and the reglator moving towards the stud without moving the spring..   easier said than done.  Take your time.
Hi and thanks for feedback.
I have tried to alter the shape from the stud towards regulator to move the collet more towards center. And as such it works...but since anything I do close to the h/s circumference also move the entire h/s and ending with that first turn outside the regulator to move against the reg pin. It’s as if I should really need to only move the collet without touching any of the other h/s turn positions. Not possible, I guess.
To me it feels like the h/s is overall a tiny bit too large diameter to fit the three points; center, regulator and stud.
Sigh....
Exactly.
If the collet is centered, the spring will touch the regulator pin. Probably this hairspring was changed in the past.
Frank
The thought has struck me as well that this may be the case.
I will try some more, maybe there’s a compromize that works?
And I was also thinking that maybe I can find a regulator from a scrap movement with a slightly longer distance from center to reg pin that offer a tiny bit more space for the first h/s turn?
Any comments to that idea?
Hi again,
Running out of ideas, I decided to try a somewhat counterintuitive approach.
With the main trouble being the h/s touching the reg pin from the outside, I decided to remedy that to start.
I slightly straightened the h/s right across from the stud i.e. Moving the entire h/s in the ”wrong” direction and effectively increasing the error between collet and jewel hole.
What then happens when ”forcing” the collet to be over the jewel hole is that the hairspring gets a bit distorted with tighter turns on the regulator side.
But....the error introduced by the straightening gets spread out over many h/s turns and there’s still space between the spring and the the reg pin.
Looks a bit ugly but runs very well again and hopefully interesting for some h/s nerds out there.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
