Watch slows down when setting time
Canon pinion friction may be a bit tight, in some cases it will actually stop the watch. Some watchmakers back in the day considered it "right" when it'd stop the watch, it gave a sort of hack system.
Imagine if you grab the center wheel pivot going up through the dial, and twist anticlockwise. You're going against the power from the barrel. This is what the canon pinion is doing.
2 hours ago, jdrichard said:
I’ll try. I was a bit disappointed as it is a nice watch.
Oh,  its as Nickelsilver said, canon pinion and perhaps minute train, with the one you on your bench.
I meant , some don't want to run regardless of the crown position, especially if the new piece has been sitting unused for couple of years.
Hi JD    Does it do the same when the hands are moved clockwise or only anti clockwise if so I second Nicklesilvers opinion on this one but also can see where Nucejoe is coming from as regards lubrication.
One other thing do the Russian manufacturers use the same oils and greases as the Swiss or are they on their own home produced oils and greases.  If so we may have quality issues here.
It's very normal; nearly every Vostok movement does that...... it's called the "poor-mans"-hack.
Nothing to worry about and certainly not a reason to send it back or "fix"-it. These are great watches and unbeatable with regards to Value/price ratio. In fact they beat nearly all, if not all Swiss watches as for sophistication & design for the price.
Just have a look at this link; what a fantastic piece of engineering for slightly over $40 !! ; https://forums.watchuseek.com/f54/vostok-2415-2416-self-winding-function-reversing-wheels-revised-5134701.html
Great article
12 hours ago, jdrichard said:
So I took the movement apart and oiled under the cap jewels upper and lower and oiled all the normal areas. Got home tonight and now the amplitude is finally good.
Out of curiosity  did you record before and after amplitude numbers?
11 hours ago, jdrichard said:
80 deg and 209 after oiling. It was a new movement.
First; 80 degrees can't be right.
Second; 209 is very low as well ...... are you sure you did set the lifting angle to 42 degrees?
Edited by Endeavor
Here are the new results with the 42 deg lift angle....very good now.76dc175cbd3dc899b84bac9b041804ca.jpg
Sent from my GT-N5110 using Tapatalk
If the lift angle is defaulted to 52 degrees  the amplitude  would be a false reading. I would  call your results  acceptable. Btw I love the amphibia  case.it is unequalled  at it's  price.
Edited by yankeedog
Agree
42 minutes ago, Endeavor said:
Maybe I go nuts like the rest of the world, but since when has a Vostok 2416b movement 21,600 BPH ?????
I'm guessing it's one of the other problems of whatever this is that's masquerading like a timing machine? According to the site below it's not a 21,600 bph watch.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Wostok_2416B
Couldn't remember what mine was so I just put it on the Timegrapher.
It is indeed a 19,800BPH movement and with the lift angle set at 42 degrees it's returning a healthy 287 degrees of amplitude at full wind, it's on its original m/s and is currently 5 years down the line from it's last service (documented here).
@jdrichard there does seem to be something not quite right with some of the data that your timing setup is reporting, unless it's something other than a 2416b of course.
[mention=1704]jdrichard[/mention] there does seem to be something not quite right with some of the data that your timing setup is reporting, unless it's something other than a 2416b of course.
So Marc. You mentioned and I saw the thin metal spring at the bottom of the second hand wheel. What is that all about. My second hand actually fell off today, so I disassembled the watch, took of the rotor and put a white screwdriver in the hole that could be the bottom of the second hand and the spring that holds it in. Then I pressed the hand on again. Did I do this right?
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
    • The two measurements of particular importance wound be the height and the strength,  the length would obviously correspond with the increase/reduction of half mm of barrel diameter. There is a big difference in price considering that the more expensive one is the shortest. The longer one might be ok ? But then it is taking up more room in the barrel, might it effect the unwinding ? I wouldn't have thought so for just that small amount.  Ideally a pro might reduce the longer one to suit. But there is some information that might help, do you have the one that was fitted to measure up, though not necessarily the right one.
