Seiko 7009 crown wont press
Hello,
I got my self a Seiko to play with, I was so happy and excited, the watch was in a good condition ( except the broken dial feet), the crown wouldnt press to advance the day but I thought something must be broken, so I disassembled the movement cleaned it oiled it and had no problems (which shocked me tbh) and I even managed to take the diashok springs off and put them back on (I am super proud of my self).
When I pressed the crown after I reassembled the movement the day changed which mafe me even more proud.
Now when I put the movement back in the case the stupid crown doesnt want to press, it does press when the movement is out.
I cleaned all the junk that was in the crown but that made no difference and here I am 3 am banging my head against the wall.
It's not the original stem is it?
If it is a replacement stem, they may have cut it a little short and there is no room to press the stem inward via the crown. Try unscrewing the crown from the stem one turn if you can, and see what happens. Then you can decide what to do to permanently fix it.
Sent from my iPad using Tapatalk Pro
I agree with Gpsluvr. If crown doesn't want to unscrew though, Sometimes the case tube can be pushed further into the case which let's the crown pressed in deeper.
How did you deal with dial plate, perhaps the broken feet let's movement free to get pushed back as you press on the crown.
You can also take the movement out of the cas and check if the stem/crown can run into the case tube. This is to verify that the crown is the correct one for the case. I've seen wrong crowns with a too fat gaskets with the effects you describe.
The crown wouldn't unscrew and I don't want to break it, I thought about pushing the case tube a bit in but it doesn't look seperate frome the case.
I didn't deal with the dial yet but I was trying with the dial ring and movement ring in so the movement was secure in its place.
The previous guy used super glue, and dealing with it wasn't fun.
Edited by Ammar
The crown does go run into the case tube fully, I do have another stem that has a fat gasket like you said.
51 minutes ago, Ammar said:
The crown wouldn't unscrew and I don't want to break it, , I thought about pushing the case tube a bit in but it doesn't look seperate frome the case.
As often mentioned, you need to apply some heat to loosen the locking agent.
Tube is always a separate part from the case but pushing it in or out is not an easy affair and not the correct solution for your problem.
Edited by jdm
A little update:
I managed to put together a stem and a crown that solved the problem but the I had to deal with the stupid broken dial feet which took me like three hours I ended up using blue tack (dial dots aren't available for me and there is no where to put them anyway) now this is the watch after I finished it.20200309_220634.thumb.jpg.615869701f98590f678b95fc424d0368.jpg
Now there is an issue: the damn thing is racing like a mad horse, nomatter what I do to the regulator it's going like 8 min/hour, I had the same problem with a Citizen befor and enden up ruining the hair spring.:Bravo:20200309_220112.thumb.jpg.55720f7501c39929f1ea7bdde17f5ec2.jpg
Hi  You cant get dial dots  ?    I shall have to send you a few  plenty to be had in the UK.  I have your address so when time permits  I will send a few out for you.  You can build a machine for soldering on dial feet If I can get the drawings I will post them also. I build mine from bits the only expense was the box and a couple of switches . You have done ok with the watch well done:Bravo:
Thanks alot, you don't have to send me any thing that's too much, I would like to see the drawings for the dial feet soldering machine that sounds a fun project :geek:
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
