Seiko 7009 crown wont press
Hello,
I got my self a Seiko to play with, I was so happy and excited, the watch was in a good condition ( except the broken dial feet), the crown wouldnt press to advance the day but I thought something must be broken, so I disassembled the movement cleaned it oiled it and had no problems (which shocked me tbh) and I even managed to take the diashok springs off and put them back on (I am super proud of my self).
When I pressed the crown after I reassembled the movement the day changed which mafe me even more proud.
Now when I put the movement back in the case the stupid crown doesnt want to press, it does press when the movement is out.
I cleaned all the junk that was in the crown but that made no difference and here I am 3 am banging my head against the wall.
It's not the original stem is it?
If it is a replacement stem, they may have cut it a little short and there is no room to press the stem inward via the crown. Try unscrewing the crown from the stem one turn if you can, and see what happens. Then you can decide what to do to permanently fix it.
Sent from my iPad using Tapatalk Pro
I agree with Gpsluvr. If crown doesn't want to unscrew though, Sometimes the case tube can be pushed further into the case which let's the crown pressed in deeper.
How did you deal with dial plate, perhaps the broken feet let's movement free to get pushed back as you press on the crown.
You can also take the movement out of the cas and check if the stem/crown can run into the case tube. This is to verify that the crown is the correct one for the case. I've seen wrong crowns with a too fat gaskets with the effects you describe.
The crown wouldn't unscrew and I don't want to break it, I thought about pushing the case tube a bit in but it doesn't look seperate frome the case.
I didn't deal with the dial yet but I was trying with the dial ring and movement ring in so the movement was secure in its place.
The previous guy used super glue, and dealing with it wasn't fun.
Edited by Ammar
The crown does go run into the case tube fully, I do have another stem that has a fat gasket like you said.
51 minutes ago, Ammar said:
The crown wouldn't unscrew and I don't want to break it, , I thought about pushing the case tube a bit in but it doesn't look seperate frome the case.
As often mentioned, you need to apply some heat to loosen the locking agent.
Tube is always a separate part from the case but pushing it in or out is not an easy affair and not the correct solution for your problem.
Edited by jdm
A little update:
I managed to put together a stem and a crown that solved the problem but the I had to deal with the stupid broken dial feet which took me like three hours I ended up using blue tack (dial dots aren't available for me and there is no where to put them anyway) now this is the watch after I finished it.20200309_220634.thumb.jpg.615869701f98590f678b95fc424d0368.jpg
Now there is an issue: the damn thing is racing like a mad horse, nomatter what I do to the regulator it's going like 8 min/hour, I had the same problem with a Citizen befor and enden up ruining the hair spring.:Bravo:20200309_220112.thumb.jpg.55720f7501c39929f1ea7bdde17f5ec2.jpg
Hi  You cant get dial dots  ?    I shall have to send you a few  plenty to be had in the UK.  I have your address so when time permits  I will send a few out for you.  You can build a machine for soldering on dial feet If I can get the drawings I will post them also. I build mine from bits the only expense was the box and a couple of switches . You have done ok with the watch well done:Bravo:
Thanks alot, you don't have to send me any thing that's too much, I would like to see the drawings for the dial feet soldering machine that sounds a fun project :geek:
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
