V & C deck watch. Advice please
Good afternoon. I have got this watch which I believe is a silver German officers marine deck watch circa 1943 by Vacheron Constantin.
My father- in- law gave me the watch in the 1970's and I had it repaired as I remember the balance shaft was damaged. It's not been used since but it no longer works and I would like some advice on what to do please.
Would it be viable to get it repaired and serviced?  Where would I go for this?
Any idea of the likely cost assuming just a service is needed?
The watch has sentimental value so would not be sold. Would anyone have an idea of its value, as this may have a bearing on how I proceed. At some stage it will be passed on to the family.
At the moment it sits in this old watch box. I could just leave it as it is and admire it?
Any thoughts.
Because of its history with the swastika on the back. Many people collect anything of Nazi German memorabilia. I would think it would fetch a good price. The movement is high quality as well. If you do intend to sell it be careful, some laws prevent such items of Nazi German memorabilia from being sold.
Follow clockboys advice you can't go wrong.
It is a jewel.
What you can do, is to search for a high quality crystal for it and who knows maybe a spare movement. A rare piece is happier in the company of it's spare parts.
You will become an appraiser on it, as you hunt it's parts.
Good luck.
A  example Issue number M10822 exactly the same model sold at Mellors and Kirk auction house in Nottingham for £3,200 in 2018 it carried a pre sale estimate of £4,000-5,000 so would expect your example to be in a similar price range.
Any thoughts.
    good show.  keep it.  nice display box,   restore that.    i think the M is for navy.     vin
Thanks for all your useful comments and advice. In view of what has been said, I would like to get the watch working and will see what the pocket watch repairers in Oxfordshire have to say.
Regards
Paul
Page 235 of Konrad Knirim Military Timepeaces has M9491 of this watch. It is a Vacheron & Constantin Geneve calibre 163 with Nickel finish.
It is a 'Class 1' 'Navigation watch (Class 1 being the best) so was for the German Navy as you have already mentioned
Sorry can't give you much more than that, but agree its a high quality collectable watch, so well worth fixing.
1 hour ago, Nucejoe said:
Is the small subsecond genuine v&c ?
Yes, there was also a more common deck watch by V.C that did not have a up down indicator  they turn very regular in auctions and go for around £1,500, there are also centre seconds deck watches by V.C.
Thanks for the info wls. I think min hand is rubbing on the crystal. I bet if op just get that sorted out, it picks up and runs.
I am fairly certain this is a caliber 162, as the 163 only has a seconds sub dial, while 162 also has an up (auf) and down (ab) indicator below 12'o clock, like seen on this watch. This is a winding indicator.
Edited by Thesecondtallestman
I'm only quoting the book, it could be wrong
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
