Is it a good idea?
JJM
I'm a newcomer to this pulling watches to bits game, thus haven't invested in any component cleaning apparatus/chems. Could I use acetone as a degreasant?..... Well obviously I could, but do you think I may suffer unforseen complications come reassembly/commissioning time?....... I was thinking small amounts in a oil tray dimple rather than a 50 gallon vat, as the cat may well meet its Waterloo in such a hazardous contraption.
Hi  Cleaning can be done using Benzine, Naptha, and rinsed in Isopropyl alchohol as it dries with no residu. The small single portion jam jars are suitable for small portions and having a screw on lid the cat will be ok....   This subject has been covered many times so for further information use the search box in the top right of the home screen there have been various discussions relating to cleaning fluids and methods.  Cheers
To expand some on what @CaptCalvin touched on earlier, you have to be careful what parts you expose to acetone. In most cases, there are a few components that are essentially glued together using a natural shellac. The acetone dissolves this shellac and the parts come loose. The 3 most common parts that are shellacked are the pallet stones, roller jewel and occasionally the hairspring stud. I have made this mistake early on and have suffered with the struggle to get everything back in place. Ammonia is probably one of the more mild cleaners in addition to the ones @watchweasol mentioned above.
I don't know if anyone has noticed, but Isopropyl alcohol is like trying to find unicorn poo at this present time, as it goes to make hand sanitiser. The price has gone from £5 to £6 a litre to about £50 to £100! This virus has brought out the worst in some people who want to make a fast buck. Be wary of anyone who is selling it too cheap, as this is probably not IPA and you'll only get a bottle of water, then find the ebay account has closed...
  • Sad 1
Some good news.Plasma extracted from blood of healed coronavirus patients' is showing good preventive properties.Nearly 8 thousand patients who have recovered and released from hospitals here are now donating blood for plasma extraction.
Sounds innteresting! Can you post from where you got it?
Showed on TV, same old approach serum are produced , surely you know from horse blood, however did not look promising for coronavirus, since same individuals were seen to contract the disease again, which showed human body incapable of producing anti-bodies to coronavirus, imunologist here are showing, the old serum is not totally ineffective after all.keep safe.
5 hours ago, transporter said:
get yourself some lighter fluid (petrol) its just as good as anything else and i use loads of it, as well as using my L&R ultrasonic cleaning solutions.
You still need to rinse the lighter fluid off though
A distilled water bath helps in between petroleoum ether (which is the proper hydrological product, formulated to clean unlike lighter fluid that contains oils and perfumes, incidentally is also cheaper) and IPA.
But what helps the most is your eyes observing each step in a clear jar against the light. If you can see filaments or any debris floating, thow it away and repeat.
Edited by jdm
To be honest all my experience so far has been with relatively new analog quartz watches. Which I have found are extremely challenging...... The components are so small....
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
