Lubricants Avail - No Charge!
sstakoff
All-
I've been inactive for a while, but starting up again. I just replaced some of my expired and expiring lubricants. I also replaced my 9010, 9415 and HP-1300 with the fluorescent
versions.
So....I have what are essentially full bottles of the following:
Moebius 9415 - expires 12/2021
Moebius HP-1300 - expires 10/2021
Moebius 9010 - expires 12/2020
Moebius 8217 - expired 11/2019
Moebius 8200 - expired 08/2019
Moebius D-5 - expired 09/2019
I am happy to ship any or all of the above to someone that will be able to put them to use. I'm sure others here will be able to offer opinions as to whether or not the expired
lubricants can/should be used. Please be considerate and only ask for what you are truly in need of. This stuff is very expensive, so I am hoping it will not go to waste.
I am happy to ship within the US for free. I can do overseas if you can PayPal me the cost of shipping.
Stu
6 hours ago, watchweasol said:
Hi  JJM  tell her the dog ate it.    A very generous offer SStakoff,  My theory on oils is the same as food the date is a guide if it tastes ok smells ok eat it and at 76 and still going (just):D
Hi there watchweasol I bet your amplitude has never been better :sleep:
9 minutes ago, rogart63 said:
Will be fun to hear you opinion on the fluorescent lube when you tested it .
Did the Keyless assembly today, so I used the fluorescent HP-1300. Works great! Shows up under a black light as bright green - very easy to see where it is, and where it isn't. So - I'm a fan!   Will let you know how the 9010 looks when in jewels later.
The fluorescent doesn't show well under camera - so the next video won't do it justice :(
I just bought a bottle of 9010 . Should last me a year or more. So next time maybe. Need some 1300 soon. So maybe test that . What kind of light source do you use. Is there a special ultra expensive Bergeon lamp.
Ha! I’m sure you can find an overpriced Bergeon if you try! I opted for the $12 version.
https://www.amazon.com/dp/B00RV8PREI/ref=cm_sw_r_cp_awdb_t1_Ty2DEb7PTN7QG
This worked fine.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
