hour gear wave washer
No oil, this is to keep the wheel down, otherwise it will ride up and the hour hand may disengage , assuming wave is the dial washer which is a 'wavy' brass ring
Sent from my ONEPLUS A6003 using Tapatalk
I would say flat isn't always true , as the bend is the bit that pushes the hour wheel down. Depending on whether the dial is flat or domed decided which way round the bend god's but happy to be told otherwise
