How remove Certina movement? (KF 404)
Sorry for asking yet another how to remove movement question!!!
I have the back off and the crystal off.  It was not a split stem.
The movement and dial do not fit out the back or the front.  A conundrum indeed.
The movement and dial move front to back about 1/16 of an inch, so it is loose in there.  And it rotates freely.  But the front and the back of the case are not wide enough to get the movement and dial out.
I think the movement would come out the back if the dial were not attached.
There is a rubber gasket still on the back rim in the photos.
As always your help is much appreciated.
-George
Hi  The fact that it rotates ok and moves front to back ok and the movement locking screws are out there is not much left to hold it except probably the rubber locking gasket, But if it moves forwards enough for you to check and see is there are dial retaining screws around the edge of the movement and if so can you gain access to the  to remove the dial.   I have attaches some certina case details in the hope they might prove usefull.
Certina C0174101103700 Case.pdf
Certina C0174101103700 Case.pdf 167.92 kB · 1 downloa
Hi watchweasol, thank you for these PDF links, great.
In my book, you win the day everyday.
Thank you, as always, for your help.  Thanks for the PDF - not really what my case construction looks like.
The 2 movement retaining screws have been removed earlier.
I just scraped off some of the gasket material. (yellow arrow)
It looks like there is a metal ring inside the case.  (red line)  This is certainly what is preventing the movement/dial from coming out the back.  Do you think this ring is removable?  If so, how might that be done.
Any ideas on how to get the movement ring out?
can I use a back press and push it out from the front?
or
maybe remove all of the old gasket and put some penetrating oil around the ring?
Do they pry out?
Open to ideas.
I am beginning to think that with this watch stuff - knowing what to do is half the battle (that and not losing any of those tiny parts ;-)
Thanks so much.  Pried the ring up after taking out the gasket gunk and it came up after a bit of a battle.
Movement and dial and movement ring are out of the case!
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
