  • 0
Ammoniated watch cleaning solution
Question
Hi Chaps,
I have for many years used a water based cleaner (from M&P) in my ultra sonic cleaner. However I recently changed the cleaner to Elma WF pro + Elma rinse.
I have been really pleased with the cleaning but the fumes I find very overpowering also a bigger concern is the wife has started to complain. Has anyone had that same issue & if so what solutions have you found. I have been trying the purchase a dedicated watch cleaning machine such as the L&R ULTASONIC VARI-MATIC or an Elma but unfortunately I keep getting out bid on flee bay.  I don,t know whether these machine control the fumes better or if other cleaners such as L&R have fewer issues with the fumes.
I might have to move the cleaning side of the operation to my garage but hoping to find another way. :thumbsd:
Edited by clockboy
Link to post
  • Answers 521
  • Created
  • Last Reply
Top Posters For This Question
Popular Posts
Ammonia is a good cleaning agent, with the added benefit as said by jdm that it brightens brass. It has been linked to stress cracks in brass, primarily antique clocks; it seems not to be an issue in
The only time fumes will be an issue is when the jar is opened.  I use L&R 566 which is labeled non-ammoniated, BUT it does contain ethanolamine which stinks like ammonia.  I typically run the cle
Posted Images
  • 0
I can say that the l&r does not dissipate the fumes. Obviously The fumes are worse during the heating/drying stage.
It's best to operate in a well ventilated area.
I used to work in a department store and we used to keep the machine in a cupboard in order to keep the floor manager happy. It helped.
Link to post
  • 0
Thanks, does the L&R have less fumes than the Elma.
Even as I poured from the bottle to the cleaner is was very strong & smelly and as my workshop is a converted bedroom in my house er indoors is not happy. So I need to find a way around this, perhaps rig up an extractor fan.
Link to post
  • 0
I used to use solvent-based paints for spraying small items with an airbrush, many years ago, also in a fairly confined area. I rigged up a small fume cupboard - essentially a plywood box with a cloth front to it and an extractor fan behind it. The fan extracted the fumes into a cloth and rubber hose contraption and out of the window. A little clumsy, but it did get rid of fumes and was less hazardous to health.
As a young man I worked for a spell on a mobile library. In quiet periods we used to clean off the stickiness on the plastic covers of books with - guess what - carbon tetrachloride! Unbelievably lethal. My colleague, one cold day, was doing it with the bus door closed, and nearly collapsed from the fumes. Luckily I came back from lunch and got her out. Modern H&S would never have allowed that to be used - but it was early 1960s.
Link to post
  • 0
Willfly,
Similar story I was an apprenticed served letterpress printer followed a by a 2 year litho training scheme. During the early days as an letterpress printer we used to use a chemical called "ink stripper" without gloves this stuff would strip paint. In my litho days another chemical was used the revive printing blankets called MEK again lethal stuff and some of the guys used to use it without gloves. If you used it a lot it could make you very light headed. No H&S them days either.
I think I will try some sort of extraction fan rigged up to a tumble dryer extraction pipe but will waited to see if I can purchase a proper watch cleaning machine. In the mean time it will be the garage for me.
Link to post
  • 0
We used to use carbon tetraclouride as a degreaser when cleaning watches years ago until the chemist stopped supplying us. I currently use MEK as an accelerant for my micro flame soldering machine. It's pretty stinky stuff.
Link to post
  • 0
Excellent time for mouth to mouth resuscitation! :crazysmile:
On a more serious note, I've heard somewhere of a filtering machine that is supposed to eliminate and decompose the harmful gasses of the watch cleaning machine....maybe at cousins? I'll try to find the link. It didn't seem very expensive...worth a try considering it is our health.
Link to post
  • 0
Willfly,
30 years in the same trade (you get less for murder) until 6 years ago, still got a can of MEK - very useful heavy duty cleaner. Never used gloves as they would either dissolve or leak. Stung a bit on the paper cuts though!
Link to post
  • 0
I've cleaned quite balances ultrasonically over the years without any problem. If in doubt, try it on an old movement first to see how you get on. The only thing I will not ultrasonically clean I'd the dial. I tried it early on and it destroyed the finish.
Edited by Geo
Link to post
  • 0
Mark re-attaches the balance to the plate prior to cleaning in his videos, and the manually cleans the jewels after. Whipping around a liquid bath seems more violent and sitting stationary in an ultrasonic cleaner so I'd assume it's safe.
Link to post
  • 0
Mmmmmmm, sloshing about may be Ok, I'm concerned that 22Mhz may mess with the hair spring..............
Link to post
  • 0
I have been collecting the tiny little Wilkin and Sons jam jars you get in some cafés, I can fit 3 in my ultrasonic cleaner and it means I can have a different fluid in each one if I wish.
The brass fine mesh balls are useful sometimes as well for the really small bits.
Like Bob and George I clean just about everything bar the dial and pointers.  The only thing I would say is dont use any solvent cleaner type substance that could dissolve the shellac/glue holding the jewels in place.
Since seeing Mark do it, I have started putting the balance back on the plate and it seems to be perfectly ok that way, it does not take long plus the plate gets a clean as well.
Cheers,
Vic
Link to post
  • 0
I have been using Mark,s method with my L&R cleaning machine (that also ultrasonic cleans in all three jars) and perfect results every time.
Pallets could be a problem if one of them is loose other than this scenario no problems.
Link to post
  • 0
I clean all my balances in the ultrasonic and have had no problems, however I have learnt to be a bit more careful with the Pallets as the cleaning solution can get a bit warm if used for an extended time period ( I personally can use it quite a lot in a one session) and sometimes Pallet jewels can come loose due to the shellac/ adhesive softening because of the increase in temperature within the cleaning solution...
Link to post
  • 0
I'm in the process of making my own experimental ultrasonic cleaning apparatus. One thing I'm not sure of is; how long do you run it for when loaded? Can someone give me an idea of ultrasonic cleaning and rinsing times please? Do the 2 rinses need to be agitated also?
thanks.
Tim
Link to post
  • 0
I give them about 9 - 10 min and sometimes if the part is too dirty an extra 3 min. My machine only do 3 min at a time, so I press the button 3 times...but sometimes I loose count so I've probably done 4 times 3 min....Never had a problem. It doesn't agitate apart from the ripple proper of the ultrasonic.
I'll be interested in this project too!
Cheers,
Bob
Edited by bobm12
Link to post
    • Yes it can;  perhaps impulse jewel can't enter the fork horn, if the shock has  knocked a pallet jewel out of alighnment or bent a pivot. Remove the two black screws then the automatic device, loosen the cock screw by couple turns, raise the bridge just enough to pass the impulse jewel over the fork so to get impulse jewel inside the horn, tighten cock screw. It will run, however , might get stuck again if pallet jewels have got misaligned or a pivot has got bent.
    • A little uninspiring.  It does run though...kinda.
    • I decided to find a knew winding pinion for my Vulcain.  I see some wear on the one I have.  I have the spec sheet on the Vulcain 120 and identified the part as #1246.  I searched around and found scotchwatch.com had one.  $45.  I really want it, so I bought it.  Meanwhile, I continued my search and found a part with a different part number (410) on Northern Watch & Clock Supplies in the UK.  It was just a couple of pounds, so I bought it. Later I looked at the invoice from scotchwatch.com and see that the part I bought is 1246 (410), so I think the part has two numbers.  Well, we will see when they arrive.  On part cost 20x the other one.  I am not complaining...as I am glad that someone takes the effort to maintain an inventory for budding watchmakers like myself.  I just think it is interesting. Learning new things every day.
    • Thank you for your introduction and welcome to this friendly forum. A nice looking watch you are wearing.
    • The hairspring is partially blocked from view by the autowinder but looks to be ok.  The balance swings with a puff in one direction but not the other.  Could it be the position for the impulse jewel and fork?
