Automaton's, a watchmaker's boast.
FLwatchguy73
Won't let me watch it in Australia. :-(
When I was last in the UK and I realised the museum that had 'The Silver Swan' in it was only a 10 minute drive away from where I was staying I made a special trip out to see it. The skill and effort some of these early watchmakers went to are just amazing.
Found another copy of it on YouTube, thanks I hadn't seen that one before.
If you are interested here is my much much simpler automaton I made years ago getting an upgrade to be steam driven.
I made this video 11 years ago for a forum I used to help run which was all about toy and model steam engines.
https://youtu.be/dVxDlRdkPfc
Edited by Tmuir
The original (1774) Jaquet Droz 'Writer'.....
HERE...
I've worked on the design and building of cam driven production line machines in the lamp making and fastener making/assemble industries and can really appreciate this.....
Edited by JohnD
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
