seiko 8c23-6059
1937
Hi we will need clear pictures of the rear of the movement  in order to see which release mechanism it has. They all differ some require pressing a stud, others pressing a small lever only visible when the stem in in the hand set position. so without the pictures we would be guessing.      This is a solar powered watch.  with a capacitor to drive the circuit block.
12 hours ago, 1937 said:
AS YOU STATED need picture of watch I have it THANKS   REPLY
That small image doesn't help much but the release end of the setting lever should appear with the correct crown position, in the round hole right of the stem, I can faintly see an arrow marking there. For your reference attached the service document.
8C22A_8C23A.pdf
3 hours ago, 1937 said:
you say the round hole right of the stem, another FORM says its the square hole push
WHICH IS IT?? DOES ANY ONE NO  FOR SURE I CANT SEEM TO GET IT OUT -- REPLY THANK'S
Answered above already, but you should post a better resolution picture.
