Rolex cal. 2030 Hair spring problem
Matej
You would need a compatible hairspring to vibrate the with this wheel, it would work even if not a dedicated hairspring,  however, Building a complete balance that can deliver the split second accuracy expected out of Rolex is however a job for competent watchmaker, who would certainly go with genuine Rolex parts.
