Barrel to right on arbor?
Stevelp
Hi everyone!  So recently after reading an article about excess friction in the barrel/arbor assembly affecting amplitude I’ve been testing the fit between the 2 without the mainspring installed.  So to test it I assemble the barrel and arbor without the mainspring installed and secure the arbor in a pin vise.  Once secured I blow the assembly with a blower.  According to the article and from what I’ve experienced the barrel should move freely on the arbor from the wind made by the blower.  I’m working on my first Omega movement, an 865 and this barrel assembly does not move freely at all.  So I’m just curious if anyone else does this, and being my first Omega I’m not sure if this is maybe normal for them?  To me it makes sense it should be fairly free to rotate.  Any thoughts on this?  And if it’s not the norm any recommendations on remedies?  I’ve seen some procedures to increase end shake with the staking set.  Any input would be greatly appreciated!
Did you properly clean/lube the arbor prior to testing?
3 hours ago, Stevelp said:
On the previous ones that I have tested I’ve always done them dry but maybe that’s something I should do with this one.
Yes you should and makes no point in doing testing on parts and movements if they haven’t been cleaned, inspected, and serviced
Edited by saswatch88
Never had the privilege to work on an Omega, so I can't say for sure, but why would they be different? The arbor and the spring still need room to move freely in the barrel.
Are you talking about this article:
https://adjustingvintagewatches.com/testing-mainspring-barrels/
There are some good tips in there about what the causes could be and how to remedy them. As long as you have cleaned everything thoroughly, I cannot see a problem with testing dry. Better than testing with a viscous lubricant on the parts, in my opinion.
Clean the holes in the barrel and lid properly, lightly oil and test. I usually move it with my finger and see if it spins. Usually the problem is too much clearance so that the barrel rocks a bit on the arbor.
Also check the barrel installed in the movement (with or without mainspring) and see if you can rock it. Too much rock and the barrel will bind up.  Usually its because the barrel pivots are worn, there are bodges to get around this but thats another story.
Anilv
Normally this check is done clean and dry, but clean and oiled is OK too. Ideally it should move with a blower but just moving it by hand will tell you if it's free. You need some endshake, not excessive, and as said above it shouldn't have too much "tilt", this is a sign that the holes need to be closed.
If holding with a pinvice you have to watch that the pinvice isn't influencing things. I prefer to capture the ends of the arbor in the flats of stout tweezers.
  • Like 5
Klassiker that's my thoughts exactly thinking there should be no difference from one brand to the next.  Yes that is the exact article that I was referring too, lots of good info in there for sure!  When I am at the point of doing this test, the parts have been pegged and put through the cleaning machine and inspected so I'm fairly confident in the fact that grim would not be a contributing factor in this case.  Nickelsilver that looks to be a much better way to do the test than what I was doing, thanks for the advice!  I can rotate the barrel by hand but there is resistance when I do so.  Maybe I should assemble it the way it is and check my amplitude reading.  That way I can have a feel of what may be too much and what may be acceptable for future projects.
Do you have endshake? It is unlikely (essentially impossible) for the holes to become tight over time, but it is possible for the cap to sit too low in the center, zapping the endshake and causing drag.
If you're motivated to do it, it would be interesting to see what your amplitude is as is, then after correcting the barrel.
Check the barrel on its own. If it's ok, then add the centre wheel. If those spin freely when meshed, then check that they turn smoothly when under torque by applying drag to the centre wheel while turning the barrel. If it becomes "lumpy" then you possibly have a depthing issue due to side-shake.
I was home for lunch and was able to check for some end shake and I feel absolutely none.  I also tried to hold the barrel and arbor in my tweezers like you have pictured nickelsilver and I was not able to hold it tight enough to keep the barrel from turning the arbor with it.  So I would feel pretty confident that the cap may have been moved in the wrong direction.
Hi everyone, sorry for the silence over the last few days.  So I was finally able to sit down at the bench and spend some time with this.  I ended up adjusting the lid of the barrel and it feels much better.  Things now move freely with a puff of the blower!
:thumbsu: Well done and thanks for starting this thread, it's been very informative!
I'm in the process of trying to figure out why a Unitas calibre 6325 of mine has too little amplitude so I'm definitely going to look into this.
So, I have now tested the "free running" of the mainspring barrel around the barrel arbor (Unitas 6325) using the techniques described in this thread, but unfortunately I'm having a hard time determining whether the "free running" is free enough or if I should or need to take some sort of action. I thought perhaps those of you following this thread might be interested in my thread (where I've also recorded a couple of videos) on this topic which stems from trying to locate the cause of a way too low amplitude. I'd really be interested in your opinions and thoughts! If so, perhaps a good starting point in my thread would be here, so hopefully I'll see you there!
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
