weishi
gary17
hey
i have just started using the weishi and im struggling on a read out on a old everite watch.
The pics below show consecutive screens.
I am presuming its beyond help unless someone know something i am missing.
I have moved the adjustment timer on the balance and it does not seem to make a difference.
cheers
gary
16 minutes ago, gary17 said:
I have just started using the weishi and im struggling on a read out on a old everite watch
The instrument is doing his job correctly, telling you this piece at the minimum needs a complete, accurate service.
1 hour ago, gary17 said:
hey
cheers
gary
You are not the only one struggling to interprit tg graphes.
Edited by Nucejoe
Poor amplitude, fluctuating daily rate, it is not running happy.
Hi Gary I am afraid there is no point putting a duff watch on the machine when trying to understand it. Out a watch on that you know its characteristics and that it is a good one that way you know the machine works and you know what you are looking at. So once having acertained how it works and able to analyse its out put then introduce a watch like the everite and analyse its out put according to the instructions. Its a new toy and will take a little time to understand.
Well you have a range of -102 to +3 seconds/day and I would say that the 'adjustment timer' (more correct term is regulator) is working fine.
If you're expecting a nice clean trace, that will only come with a strip-down, inspection and assembly with correct oil in correct amounts. There are no shortcuts.
Anilv
34 minutes ago, StuartBaker104 said:
Assuming that the watch is nearly fully wound and you've set the lift angle correctly for this movement then the amplitude
Worth to remind that even without bothering to set lift angle, or having a "large" discrepancy of 5°, the amplitude value is not greatly affected and will be accurate enough for making a go/no to call.
Besides the obvious lack of amplitude, I think an important thing to check is to see if stud is loose in stud carrier. Other things to look out for are loose index pin and boot, index, harispring either at collet or stud end, shock assemblies, as well as condition of the pivots.
Edited by CaptCalvin
I'd think anything loose there would show an irregular beat error (spacing between the lines).  That really looks like the good part here.
